O-NEX HID kit help
I've never installed an O-NEX HID kit but I would imagine that if it is not turning on, try to turn on your high beams. If that does not work run through the following.
Is the plug that connects your ballast to your OEM connector plugged in correctly?
Plugs from the ballast to bulbs connected properly?
Check to see if the fuses are still good.
Those are some good start points.
spotscivic
21
May 16, 2007 05:13 AM
GQ 05YellowEVO8
Feb 9, 2002 07:19 AM
