Exhaust with no CAT. Good or bad.
Old Jun 6, 2008 | 03:29 PM
Happy Gilmore's Avatar
Default Exhaust with no CAT. Good or bad.
I have a megan racing muffler turns out I am gonna have to have the pip custom fabricated. The gentleman at the shop offered to remove my cat. I would like to know is that good or bad. I am of course not just doing this for sound. I would also like to know what a good cold air intake would be and do for my car. Obviously a short ram won't do me justice since I have been reading on here alot more. Thanks in advance.
::Edit::
I have heard that it was bad for not cat, but then again I am not sure. I may also add my O2 sensors will still be in place on the fabrication.
Old Jun 6, 2008 | 03:55 PM
nuke08dog's Avatar
Default Re: Exhaust with no CAT. Good or bad. (Happy Gilmore)
Well, as far as I can tell, removing your cat is going to free up the flow of your exhaust, thus more hp. However there is no way you can pass a smog test for inspection if youre in say California or Texas. It will make it slightly louder as well.
I think the best route to go is to figure out how to get a cat installed that can be unbolted. Then you could switch it out with a test pipe that matches the size of your exhaust pipes. That at least is what I am trying to figure out how to do right now.
Old Jun 6, 2008 | 04:38 PM
s13_240sx_92's Avatar
the guy will gladly take the cat off your hands and sell it for scrap for $$
keep it. your car will smell like sh*t with out it. you have a good chance of throwing codes too.
Old Jun 6, 2008 | 04:54 PM
Default Re: Exhaust with no CAT. Good or bad. (s13_240sx_92)
I live in MO btw. I plan on keep the stock parts . Well now that I know I will do some more research from there.
Old Jun 6, 2008 | 04:57 PM
h23siaws's Avatar
i have a test pipe in my 4th gen prelude with cai, i does make it loader, it does add more hp, but it does not make any extra smells. also you will see a lot more carbon build up on your muffler. if you have emissions testing keep it, but besides that it does attract more attention from the piggies.
Old Jun 6, 2008 | 05:05 PM
nuke08dog's Avatar
Default Re: Exhaust with no CAT. Good or bad. (h23siaws)
h23siaws, do you have a cat that bolts on or did you just scrap it. Also, I agree about the smells. As long as it's not dumping under the cab there shouldn't be anything to smell.
Old Jun 6, 2008 | 08:39 PM
BMan88's Avatar
The smell is for people behind you or if you are sitting still, kind of a rotten egg smell. It will only give you 3~5 hp but is bad for the air. It may make your car use more gas, it may throw codes, or it may do nothing more than polute.
Old Jun 6, 2008 | 09:27 PM
gstrudler's Avatar
Default Re: (BMan88)
Don't remove your cat. It's not worth the couple of hp you might get, and you can get a good high-flow cat that will make just as much power (or very close) as no cat.
Old Jun 7, 2008 | 06:54 PM
SikB's Avatar
Default Re: (gstrudler)
I removed my cat when I did an h22 swap in my 96si. The only reason I did it was because the original had to be hacked up to get it out. Their is no way I could have reused the thing. It doesn't add a smell for me or anyone else and I don't throw codes or get worse mpg because I switched to obd1 anyway. If I every replace my whole exhaust system I will put on a high flow but it isn't worth it until it rusts out or I move to an e-check county.
Old Jun 7, 2008 | 07:29 PM
So I got my car back this afternoon. The cat is gone. Sounds pretty good. I need to find some time to place a high flow and test pipe in place. My check engine light is on and I know why that is. As for my ATTS light well that I don't know why. I will look arround to find out why that is. I will keep you all updated...looks like I am gonna build this bad boy to the best of my ability and you alls help. Thanks
Old Jun 7, 2008 | 07:38 PM
98vtec's Avatar
moderator emeritus
Default Re: (Happy Gilmore)
ugh.
street car = cat.
good bye.
srm238
Jan 13, 2010 03:49 PM
ShinotakuX
Nov 5, 2007 01:25 PM
hatch_
Jun 26, 2007 06:05 PM
lucint
32
Feb 1, 2003 09:05 PM
baonest
Jul 18, 2001 10:07 AM
