Hondata S300 and O2 wideband options
Old Jun 6, 2008 | 03:17 PM
yakuza's Avatar
Default Hondata S300 and O2 wideband options
Ok, so we have established that the S300 will work with a wideband O2 sensor and controller, preferably PLX since others encounter voltage differences problems.
But what I can't seem to find a defenitive answer for is wether can the S300 be connected directly to an O2 wideband sensor and can it control it or not?
I'm trying to decide this as someone here offered me PLX R-500 controller along with everything. I've seen most mention PLX 300 and 100 but non have used the R-500 with it!!!
Your feedback and input is very much appricated ..
Old Jun 7, 2008 | 03:07 PM
mtber's Avatar
Default Re: Hondata S300 and O2 wideband options (yakuza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yakuza &raquo;</TD></TR><TR><TD CLASS="quote">Ok, so we have established that the S300 will work with a wideband O2 sensor and controller, preferably PLX since others encounter voltage differences problems.
Your feedback and input is very much appricated ..</TD></TR></TABLE>
Hondata only uses a 0-5 volt lamda input from your wideband for datalogging & lean protection etc.
Old Jun 18, 2008 | 08:00 PM
LudeLooker's Avatar
If you want to use an AEM you will also need to wire it to D10 (ELD IIRC) as the standard O2 input won't read 0-5v, I think it only goes up to about 3.8v, which on other WBO2's doesn't matter but with some it does, personally I would save yourself the hassle and just wire it to ELD
Old Jun 18, 2008 | 09:09 PM
mtber's Avatar
Default Re: (LudeLooker)
If you wire anything to ELD make sure you cut the two resistors needed per the hondata help file instructions.
King V
Nov 30, 2007 04:40 AM
nah22accord
Oct 24, 2005 09:02 PM
red_sir
Jul 23, 2003 02:14 AM
madman604
Apr 29, 2003 01:44 PM
