ACL bearing clearances--for those interested.
Old Jul 16, 2002 | 06:53 PM
GruvyTune's Avatar
New User
Default ACL bearing clearances--for those interested.
I got a set of ACL bearings, standard clearances for my GSR rebuild. I got them from Earl (Earl and Rocket were both very helpful). They look a bit different than OEM and have a dull surface on them that seems to scratch easily. Fitment is like stock. I plastigauged my main bearings today and they are all within spec. Not exacting like Honda but I am roughly between 0.0016 and 0.0020 which apparently should be just fine. We'll see about the rod bearings tomorrow with the Eagle rods.
Old Jul 16, 2002 | 07:09 PM
tinkerbell's Avatar
Default Re: ACL bearing clearances--for those interested. (GruvyTune)
are the ACL's meant to be bettor?
why not use stock? is it a price thing or performance based?
t..
Old Jul 16, 2002 | 08:11 PM
GruvyTune's Avatar
New User
Default Re: ACL bearing clearances--for those interested. (tinkerbell)
these guys are swearing they are better than oem. they come in larger sizing but thats only if you have to grind your crank down. Otherwise std. size puts you in spec.
Old Jul 16, 2002 | 11:02 PM
CivicEK.PDX's Avatar
.002 is service limit. I get a slight knock on start up while the bearing is filling up with oil...and this is on stock OEM bearings. .0016 is PERFECT...002 is service limit
Old Jul 17, 2002 | 04:40 AM
GruvyTune's Avatar
New User
Default Re: ACL bearing clearances--for those interested. (CivicEK.PDX)
i thought it was better to have a little more clearance with a higher hp car since the more oil will allow better bearing cooling?
Old Jul 17, 2002 | 11:43 AM
Rocket's Avatar
Running .002 is fine. Service limit on GSR's are like 0.0025. I'll have to double check my factory manual.
If you look in the Factory manual the GSR clearance are higher than LS.
I not only swear by ACL's I'll put my whole reputation behind these bearings.
Old Jul 17, 2002 | 11:59 AM
irev210's Avatar
Default Re: ACL bearing clearances--for those interested. (Rocket)
what makes them better? just curious?
Old Jul 17, 2002 | 12:14 PM
Rocket's Avatar
Default Re: ACL bearing clearances--for those interested. (sirhatchback)
Their Duraglide 780 sintered copper-lead alloy is ultra strong. The top lead overlay is very thin and highly fatigue resistant and won't "hen track" like OEM bearings.
The quality of manufacture is also higher if you have OEM vs. ACL side by side you'll see the difference.
I know a racer that spent over 100K in his race car and choose these bearings exclusively. I know I supply him.
Old Jul 17, 2002 | 12:18 PM
earl's Avatar
ACL's are made with the same manufacturing process as Honda, they just don't come in the .0001 adjustments by colors. They match the green color code in most instances. They are a one size fits all that will give you clearances right in the middle of the specs. I use them in my own 9.40 @ 156 set-up as well as all the motors I build for customers. I have never seen a failure on an ACL bearing. Remember, if you switch to aftermarket rods (Crower, Eagle, Manley) your color codes don't work anymore.
Earl
Old Mar 11, 2008 | 11:11 AM
MeanGreenMachine's Avatar
Default Re: ACL bearing clearances--for those interested. (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by earl &raquo;</TD></TR><TR><TD CLASS="quote">Remember, if you switch to aftermarket rods (Crower, Eagle, Manley) your color codes don't work anymore.
Earl</TD></TR></TABLE>
does this still ring true?
Old Mar 11, 2008 | 01:47 PM
Phre0nBurn's Avatar
Lol
Damn dude... Talk about picking an oooolllllllddddd thread. lol
Old Nov 9, 2008 | 01:13 PM
NSU.FL's Avatar
Default Re: (Phre0nBurn)
Can someone please provide me with clearences on a LS motor. I am using ACL race bearings as well. Also what would be a recommended spec for a boosted application? Thanks
Old Nov 13, 2008 | 05:35 PM
NSU.FL's Avatar
Default Re: (NSU.FL)
up
Old May 22, 2020 | 05:37 AM
Brandon Snyder's Avatar
sooo i have a question. with the acl standard size bearings do i wanna go with factory clearance then or?? im a b18b1 with b16 head .. ive seen soo many different things its wild
Old May 22, 2020 | 09:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Factory clearance is fine if you are staying NA.
ilikebigbutts
Jan 22, 2007 07:55 PM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
totalimpact
Nov 11, 2003 06:39 PM
1.8T_EG
Feb 1, 2003 08:47 AM
GruvyTune
Jul 17, 2002 07:42 PM
