OBD-0 OBD1 ignitor the same?
Old Jul 16, 2002 | 06:51 PM
giooooo's Avatar
Default OBD-0 OBD1 ignitor the same?
I did a search function already i couldnt find anything...... i have my friends 90 integra LS sitting dead in front of my driveway. We bought a brand new coil... there is spark.. but no start... i checked every wire connected to the dist...do you think it is the ignitor??.. i have 3 obd1 ls distributors in my garage..do you thin the ignitors are interghangable?.... he locked his car went home told me not to touch it but im wondering now....any ideas?
Old Jul 16, 2002 | 07:24 PM
kinesistech's Avatar
Default Re: OBD-0 OBD1 ignitor the same? (Giovannie)
If you are getting spark, ignition is not the problem. Obd0 and obd1 ignitors are different. The obd0 uses a capacitor while the newer one dont.
Old Jul 16, 2002 | 07:35 PM
BreakStuff's Avatar
New User
did you do any work on the car before this condition occurred?
3 major conditions that have to be met to make a car run..
Spark..
Fuel..
Combustion...
Old Jul 16, 2002 | 07:41 PM
Default Re: OBD-0 OBD1 ignitor the same? (BreakStuff)
5 Air, spark, fuel, timing and compression.
Does it crank over faster than its supposed too? That will be a sign of no compression. I assume the plug wires were already correct. Try pulling the plugs and see if they're too fouled to create a spark in the cylinder.
[Modified by kinesistech, 4:44 AM 7/17/2002]
Old Jul 16, 2002 | 08:01 PM
BreakStuff's Avatar
New User
Default Re: OBD-0 OBD1 ignitor the same? (kinesistech)
Ha!... I goofed , compression should be #3 and not combustion, i was waiting for someone to include timing but if timing was off, compression would not exist, well not sufficiently.. my brains going mush.
[Modified by BreakStuff, 12:02 AM 7/17/2002]
Old Jul 16, 2002 | 08:33 PM
giooooo's Avatar
thanks man ... now i know the differences between the two ig nitors.. well i was just trying to help out a friend.. but thankz guyz
minime-dom
May 19, 2010 06:31 AM
menappi
Sep 21, 2005 03:41 PM
Urban Business
Jan 21, 2003 12:50 PM
