Loco-b's Progress Thread (F20B + CD7)
Old Jun 6, 2008 | 01:47 PM
Loco-B's Avatar
Default Take a Shot in the Dark - CD7 + F20b (how to swap a motor in 50 days)
A lot of you may ask, "why not the H22a?" Well beyond the average answers you get, like "more torque" and "more displacement" I decided to go against the grain. My reasoning behind it all can be summed up in one word, "unique." For those of you who are not educated; the F20b is similar and not, to the h22a, in several ways.
F20B
Accord/Troneo Sir and Sir-T (CF4) (JDM)
197hp@7200/145tq@6600
85mm bore
88mm stroke
145.5mm rods (f20b rod length = 145.425)
1.65 r/s ratio
55mm mains
11.0:1 cmpr
23mm wrist pin
Iron Sleeves
You can do the comparison to an H22 on your own, i don't feel like searching.
I will have help from a good friend and wheel *****: Toyomatt84. He's actually part of my inspiration in this project as he stepped out of the realm of normalcy last year when he put a k24a2 into his EM2.
Pictures will be thrown up as often as possible. I will try to answer your questions when I can, pending the fact I actually have an answer. I am taking a shot in the dark, so please bare with me. I will need your help as well and in return you shall all be enlightened.
On with the pics.
Parts List:
Already In Possession of:
Boomslang OBD2A to OBD2B conversion harness
P5P unchipped ECU
F20b motor
T2T4 F22b Trans
new Stock t2t4 clutch
new Clutch master
new clutch Slave
new clutch release bearing
[Lots more to list]
In need of(OE parts WTB):
Radiator
Exhaust manifold (to Cat) or 2nd half mani to cat
Lots of 12-18 guage wiring
Heatshrink
Power Steering bracket from H22 - 97-2001
Drivers side H22a Motor mount
[the rest is unknown for now]
Performance Parts(wish list):
Cusco Front Upper Strut Bar
Tanabe 32mm Front Sway/Anti Sway
Suspension Techniques 29mm Rear Sway
TasPro Uerethane Sway Links
Explicit Speed Performance Exhaust Mani
A little background on the car:
Aero
CD6 SiR Headlights
CD6 SiR Rear Flush Mount Spoiler
CD6 SiR Honda Genuine Front lip
CD6 Accord Coupe Window Visors
CD6 Power-fold mirrors(see write up in Accord FAQ)
CD6 Stanely Stamped Sidemarkers
Work/Anhelo Rear Lower Valance
JP Racing Grille
Garson Eyelids (lost in the wind )
Grip
Tanabe Sustec Pro OC Type II's (installed last weekend)
Rollers
Advan Touring Competition's
17x7.5 +45mm Offset Pearl White/Blue
4x114.3
Advan Siena Road Battler's
f=17x7.5 +40mm Offset
r=17x8 +35mm Offset
4x114.3
Little Side Project With these
https://honda-tech.com/zerothread?id=2058609
Rubber
Yokohama ES500 dna-S drives 215/45zr17
Exhaust
Apexi-WS2
Foto
Nikon Coolpix 8700
8.0mega pixel
8xOptical 4xDigital
Last Year Sept
How it sits Today:
So let's start this already.
Modified by Kurumi at 11:04 PM 6/6/2008
Modified by Kurumi at 11:40 PM 6/8/2008
Modified by Kurumi at 10:07 PM 7/9/2008
Modified by Loco-B at 7:50 PM 8/12/2008
Old Jun 6, 2008 | 02:06 PM
erk89's Avatar
Default Re: Quest For Import Alliance 08' - CD7 + F20b (Kurumi)
50 days to get it up and running smoothly...you're in for one hell of a power build. Keep us updated, love to see the final result!
Old Jun 6, 2008 | 02:26 PM
Loco-B's Avatar
Default Re: Quest For Import Alliance 08' - CD7 + F20b (erk89)
should be good to go. Motor was pulled from a CF4 with 22k on the ODO. Compression tested excellent accross the board.
can't get too optimistic, and i always prepare for the worst
Old Jun 6, 2008 | 04:56 PM
momstaxi's Avatar
be sure to get a 97+ p/s bracket
should be pretty sweet, looking forward to seeing it swapped
Old Jun 6, 2008 | 05:10 PM
Loco-B's Avatar
Default Re: Quest For Import Alliance 08' - CD7 + F20b (momstaxi)
Thanks for the info Momstaxi!!!
unfortunately the harness that came with the motor was cut. So now im at a stand still till i can source a full (uncut) harness. Im thinking i might be able to run an h22 harness, however that may be too much wiring, and end up in disaster. We will see. Still under the crunch so any help with sourcing a full harness would do wonders. $25 finders fee for anyone that can come up with something before I do.
Modified by Kurumi at 9:40 PM 6/6/2008
Old Jun 6, 2008 | 05:53 PM
toyomatt84's Avatar
Sanji
It's going to be tough, fun, back-busting, and exhilarating... all in the same swing.
It's all good though, I think we can source some info. about your wire harness, and get it sorted.
Old Jun 6, 2008 | 06:24 PM
B16B_coupe's Avatar
HRD PKR
Default Re: (toyomatt84)
Hell yeah! See you at IA
Old Jun 6, 2008 | 06:25 PM
Loco-B's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 &raquo;</TD></TR><TR><TD CLASS="quote">I think we can source some info. about your wire harness, and get it sorted. </TD></TR></TABLE>
I think your right. Already it looks like the right h22 harness will be some form of usable......in fact we might even be able to modify it with specific connectors needed for the f20b harness.
Oh pics of the OBD2B to OBD2A conversion harness from Boomslang. Pricier than some of the other harnesses i saw but quality work for sure!!!
Modified by Kurumi at 9:39 PM 6/6/2008
Old Jun 6, 2008 | 09:18 PM
oem_certified_accord's Avatar
Default Re: (Kurumi)
kurumi! you know i'm gonna be checking this thread everyday man
Old Jun 6, 2008 | 11:25 PM
Bense's Avatar
Default Re: Take a Shot in the Dark, Quest For Import Alliance 08' - CD7 + F20b (Kurumi)
N 4 L8R
Old Jun 7, 2008 | 09:58 AM
Loco-B's Avatar
ok so i actually took note like two weeks ago that the radiator was looking shotty.
So yesterday on the way to work without warning.......BAM!! my temp guage is running close to red.....so i only figured as much.
yup...pissing coolant out the rad...
Wanted to get a Koyo, but decided to keep it stock till some other time.
Replaced
Also replaced some of the hardware with rust proof bolts.
Old Jun 7, 2008 | 10:03 AM
Jorymi's Avatar
Let me know when you start pulling the motor out. I'll be there to help. Then it'll be my turn to do it
Old Jun 7, 2008 | 10:10 AM
Loco-B's Avatar
Default Re: (Jorymi)
you know it man.
Once i get it out, i'm cleaning my bay....Period. Every last square inch of it.
Old Jun 7, 2008 | 10:20 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kurumi &raquo;</TD></TR><TR><TD CLASS="quote">Once i get it out, <U>i'm cleaning my bay....Period. Every last square inch of it.</U> </TD></TR></TABLE>
lol i was gonna say do work son!
Old Jun 7, 2008 | 11:08 AM
toyomatt84's Avatar
Sanji
Epic Rad failure. Well, at least you've got a nice shiny replacement.
Old Jun 7, 2008 | 11:42 AM
JcDrMx's Avatar
yo I can help a fellow in need and my buddy middwest aaron can do some mean wire work!
Old Jun 7, 2008 | 12:02 PM
Loco-B's Avatar
Default Re: (JcDrMx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JcDrMx &raquo;</TD></TR><TR><TD CLASS="quote">my buddy middwest aaron can do some mean wire work! </TD></TR></TABLE>
ill keep that in mind.
Old Jun 7, 2008 | 12:13 PM
JcDrMx's Avatar
please do! and mee too ill bring the tacos!
Old Jun 7, 2008 | 02:21 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JcDrMx &raquo;</TD></TR><TR><TD CLASS="quote">please do! and mee too ill bring the tacos!</TD></TR></TABLE>
Well, if you wouldn't mind making mine sans taco sauce. That stuff makes me sick to the stomach.
Old Jun 7, 2008 | 03:47 PM
Silvertc's Avatar
Here is all of us from last year, when you got pulled over lol, and toyomatt84's brake line broke!
And a nice picture of it at the meet...
Old Jun 7, 2008 | 03:53 PM
Loco-B's Avatar
Default Re: (Silvertc)
lol that wasnt the only time i was pulled over that day.....
i officially spoke with 3 different officers within a 12 hour window....and somehow didnt receive a ticket. and leading up to that day I was the guy saying "i dont want any extra attention on the way down, we shouldnt drive like asses."
Old Jun 7, 2008 | 04:09 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silvertc &raquo;</TD></TR><TR><TD CLASS="quote">Here is all of us from last year, when you got pulled over lol, and toyomatt84's brake line broke! [i mg]http://i41.photobucket.com/albums/e254/nguyen06/Import%20alliance/DSC05336.jpg[/img]
[im g]http://i41.photobucket.com/albums/e254/nguyen06/Import%20alliance/DSC05465.jpg[/img]
Alright now, we get it... yes I broke a brake line, can we get past it now?
Old Jun 7, 2008 | 07:55 PM
JcDrMx's Avatar
Well, if you wouldn't mind making mine sans taco sauce. That stuff makes me sick to the stomach. </TD></TR></TABLE>
weak!!! i guess you can have a white taco! hard shell too im assuming?
Old Jun 7, 2008 | 08:41 PM
c0l7hy's Avatar
gettin reay for ia. that gets me excited. good luck
Old Jun 7, 2008 | 10:21 PM
Loco-B's Avatar
Default Re: (c0l7hy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by c0l7hy &raquo;</TD></TR><TR><TD CLASS="quote">gettin reay for ia. that gets me excited. good luck </TD></TR></TABLE>
thanks man. Its really too bad im trying to do this all last minute. I feel so unprepared. Last year was too easy....course this year i plan on popping the hood.
