mixing blocks and heads
Old Jun 6, 2008 | 08:47 AM
Blue00Si's Avatar
Default mixing blocks and heads
i am about to get a b16 block thats sleeved and bored to a 2.0. i am not sure on this but i was told i can put my 94 gsr head on it. is there anything that i need to modify? what arp headstuds do i need to get etc any help would be great!
thanks in advanced!!
Old Jun 6, 2008 | 11:37 AM
havok hybrid's Avatar
Default Re: mixing blocks and heads (Blue00Si)
Your good to go. ..
You need b16 head studs.
Old Jun 6, 2008 | 11:59 AM
chrisnolimit's Avatar
Default Re: mixing blocks and heads (havok hybrid)
He would need GSR head studs not b16 studs.
Old Jun 7, 2008 | 04:26 AM
gibsanez's Avatar
What crank is this using? You might want to find out.
Old Jun 9, 2008 | 07:01 AM
Blue00Si's Avatar
can any one chime in and let me know which it is please?
ill find out about the crank asap
Old Jun 9, 2008 | 09:24 PM
96cgpteg's Avatar
Default Re: (Blue00Si)
you need GSR headstuds. the b16 ones are going to be too short.
Old Jun 11, 2008 | 10:13 AM
Blue00Si's Avatar
well just had a problem with my stock gsr motor last night. got done racin a diesel lol and after that my car had no power and it sounds like a wrx. i think i blew a cylinder. now the car wont start at all so the project is going to start sooner then i thought. going to pull the head off today and check plugs for oil etc. then this weekend try to pull the block. man not having a daily sucks lol
Old Jun 13, 2008 | 05:48 AM
Blue00Si's Avatar
well i picked up the block last night and pulled my head. i have a question on the built block it has indents on the tops of the pistons which look like it had some valves hit the tops of the pistons. its only on the exhaust side . i dont have pics at the moment but is this something i need to have looked at or should it be ok. The indents arent deep into the tops you can just tell that the valves hit them.
please chime in thanks
Old Jun 13, 2008 | 06:00 AM
gibsanez's Avatar
So what crank is this "2L" b16 using?
Old Jun 13, 2008 | 07:46 AM
DonF's Avatar
Default Re: (96cgpteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96cgpteg &raquo;</TD></TR><TR><TD CLASS="quote">you need GSR headstuds. the b16 ones are going to be too short.</TD></TR></TABLE> I hate bad info. B16a blocks, because they are shorter than GSR blocks require B16 studs. B16B blocks require GSR studs because they are the same height.
Old Jun 13, 2008 | 09:32 AM
96cgpteg's Avatar
Default Re: (DonF)
yeah very true. mistake on my part i should have read his post better . i thought he was using a gsr block with a b16 head. but yes use the b16 studs because of their shorter deck height.
BrooksGSR
Oct 6, 2009 01:37 AM
95civic16
Apr 23, 2008 06:14 AM
ol'skool ferio
Apr 15, 2008 06:31 AM
delsoldrew
Jun 22, 2007 06:09 PM
1crazysir
Oct 1, 2006 07:36 AM
