rebuilding b18c5 for low boost. Need some help+recommendations
I have a b18c5 with bad ring lands on one piston. I am rebuilding it with a friend (as long as the cyclinders are within spec). I plan on putting something like 9.5:1 - 9.7:1 pistons with eagle h beams in it.
I will need to run this car probably for about 6 months no boost because I need to buy a teal wastage rebuild my turbo and buy a hondata boost ecu.
My questions are this... what pistons do people recommend. I am only planning on running minimal boost. Maybee 4-6 lbs. I am not sleeving the motor.
Also as far as the head is concerned how hard is it to replace seals in the head and is it necisary?
I was told by my friend that on a car only making ~300 I could re-use the factory head bolts... However I have allways been told not to because they stretch to yield. I may just buy arp head studs...
As far as berings which brand should I get and how hard is it to "plastigauge" them? Are the berings easy to mess up? What do I need to ensure when I do this.
What other parts should I replace while doing this?
So far my list is:
Timing belt
Tensioner
water pump
berings
hondata intake gasket
STR cam seal
factory replacement head gasket
Valve Cover Gasket
Plugs
Cap
Rotor
oil+filter
What else am I going to need?
Also is it safe to run on a stock ecu like a gsr or prelude? I have an innovate wideband that will be installed so I will have some indication of lean/rich.
So far my list is:
Timing belt
Tensioner
water pump
berings
STR cam seal
Valve Cover Gasket
Plugs
Cap
Rotor
oil+filter
I'm sure any piston including stock would be fine for 4-6 psi. However since your pulling it appart and rebuilding you mine as well do an aftermarket piston. I've used and will use again CP pistons. Had great luck with them.
No, 4-6 psi is not enough to get close to 300whp. If you know your gonna be boosting for a while and are doing rods and pistons, I would do that and get a 9:1 compression ratio. That way you can run more the 4-6psi and have no problems at all makeing 300whp.
dsturch1
Mar 25, 2008 06:16 PM
Wrath of VTEC
Sep 15, 2003 06:24 PM
951, 973a1pistonsinb18c5, b18c5, b18cr, bad, boost, built, cp, low, pistons, rebuild, rebuilding, recommendation, ring, turbo
