2000 Prelude SH Misfire
Old Jun 6, 2008 | 05:43 AM
JDM EJ2's Avatar
Default 2000 Prelude SH Misfire
My friend has a 2000 Honda Prelude SH. Its throwing codes for misfires in cylinders 1,2,3, and 4 and also a random misfire... The CEL goes on and off as it pleases and right now we are stumped. Also, this car burns alot of oil, but we heard that it is typical of this engine... Its more or less 2 qts. for every 3000 miles. Anyone, with any idea of whats going on here, please post. Thanks in advance guys.
Old Jun 14, 2008 | 04:10 PM
JDM EJ2's Avatar
Default Re: 2000 Prelude SH Misfire (JDM EJ2)
Bump, we need help.
Old Jun 14, 2008 | 04:16 PM
Hawkze_2.3's Avatar
What do the plugs look like? What have you guys tried so far to fix it? I'd start with a good tune up...
Old Jun 14, 2008 | 07:17 PM
JDM EJ2's Avatar
Default Re: 2000 Prelude SH Misfire (Hawkze_2.3)
We did a tune up 7000 miles ago which included plugs, wires, dizzy cap, rotor, and fuel filter. The plugs are bronzed over and look fine. We did a pressure test and everything was fine. We put in a B&G fuel additive which cleans injectors, (its proven, I own an automotive shop and it works wonders, better than Sea Foam.) Is it possible that the ECU could be fried?
Old Jun 14, 2008 | 10:40 PM
Hawkze_2.3's Avatar
You could try another ECU and see if that changes anything...
Old Jun 15, 2008 | 09:36 AM
vinuneuro's Avatar
What brand spark plugs and wires? When's the last time the valve lash was adjusted?
Old Jun 15, 2008 | 10:19 PM
TheJGB3's Avatar
I was receiving misfire codes with a flashing CEL on my 2000 SH, it turned out to be the EGR valve.
Old Jun 17, 2008 | 04:46 PM
xtal's Avatar
Been through this nightmare..
Clean your EGR valve and get the EGR plugs out on the intake manifold and clean the runners. It will take an afternoon, and you need to remove a bunch of stuff.
It is most likely EGR if the light is coming on at low load, low RPM, high gear kind of driving.
Old Jun 17, 2008 | 05:10 PM
ivredrider's Avatar
they do burn oil , dont worry about it. its how the engine is designed. all four misfires could be a vtec pressure problem. if the oil is more thant 1.5 quarts low vtec will not work properly, and or clogged the screen in the spool vavle, engauging the vtec at the incorrect time, causing codes or misfires.
Old Jun 19, 2008 | 03:56 PM
JDM EJ2's Avatar
Default Re: (xtal)
We may try to clean the EGR since you had the same problem. Thanks a lot.
Old Jun 19, 2008 | 05:13 PM
spoonfedcrx's Avatar
i would def look into the egr valve. also make sure ur running ngk plugs and oem wires, cap and rotor.
Old Jun 20, 2008 | 03:59 PM
JDM EJ2's Avatar
Default Re: (spoonfedcrx)
It is running the OEM NGK's, but it has NAPA wires, cap, and rotor. Those parts are the last of my concern considering we primarily use NAPA products on every vehicle that passes through our shop. The wires are by Belden and are of very good quality. All NAPA products meet or exceed OEM standards. I think the EGR is the best bet and I will post when we try to fix it.
Old Jun 20, 2008 | 04:05 PM
Default Re: (JDM EJ2)
im not saying the aftermarket ignition stuff is junk but it my experience as a honda tech i would only use oem ignition parts. but like i said ur egr valve and the ports that are probably clogged are most likely ur problem.
guywitaDA
Nov 4, 2010 12:06 PM
nateg_93lude
Oct 23, 2009 03:28 PM
contractkiller
Dec 1, 2007 04:31 PM
Black2000Prelude
Oct 31, 2006 08:51 AM
JDMLoser
Jan 1, 2006 01:20 AM
