Weird Problem 97 civic jdm b16a
Old Jun 5, 2008 | 10:55 PM
boostedjdmdc2's Avatar
Default Weird Problem 97 civic jdm b16a
So im driving today and my speedo seems to go out along with the odometer. Later im driving and my lights dim and my cd player cuts on and off when i have my turn signal on. i jumped out to figure out was wrong and tried to restart it and it wouldnt start. so i gave it a second and finally it started allowing me to drive home, with my lights off because when they were on it would damn near die. i didnt have enough time to check it out tonight since i have to work in the AM but anyone got any ideas of what could be wrong?
Old Jun 6, 2008 | 07:16 PM
anyone?
Old Jun 6, 2008 | 07:25 PM
elektronsi's Avatar
Default Re: (boostedjdmdc2)
could be an alternator issue, or you might have a short somewhere, get that alternator checked at your local auto parts store
Old Jun 6, 2008 | 07:37 PM
v8 integra's Avatar
Default Re: (elektronsi)
i had that problem...it turned out my DX cluster had a short in it or somthing..and wen i unplugged it it ran fine..then i got a ex cluster and it ran perfectly fine...i hope that helps
Old Jun 7, 2008 | 09:06 PM
ill check out the cluster tomorrow. if that doesnt help then ill check the alternator also.
Old Jun 7, 2008 | 10:15 PM
Mikej425's Avatar
the lights being on affecting the car running would make me think it's an alternator problem or even something as simple as a loose battery cable. get it checked out and if it's not either of those it's probably that cluster problem mentioned earlier
Old Jun 8, 2008 | 12:37 PM
well went to start my car this morning and it started up. turned it off. tried to start it and it was dead. used a batter charger to start it and that worked. took it off. tried again and no start. would this be a battery problem? it just seems like the power gets drained so fast unless the motor is running
Old Jun 8, 2008 | 01:35 PM
97ej6dx's Avatar
OOO OHH HHH i know lol this happend to me 2 along time ago it ended up being my alternator. my car ran like crap my speedo and lights and every thing dint work and when i shut it off it dint start up again so i called my dad and hes like "its your alternator" so i replaced it and it was all better
Lambo123
Aug 4, 2013 02:11 PM
h22accord101
20
Dec 4, 2010 12:16 PM
akaEsCo01
Aug 18, 2003 09:39 AM
ShakesTheKlown
Jul 1, 2003 02:05 PM
