H22 Low Rev Limit
Old Jun 5, 2008 | 08:30 PM
Lou_EM1's Avatar
Default H22 Low Rev Limit
I asked this in the Prelude forums with little feedback, I'm confident I'll get better response here.
I've done a lot of searching but a lot of common 'safe mode' issues seem to deal with VTEC or CELs - mine's not. This is on a pretty much stock jdm H22a with virgin p13.
Here are my symptoms:
Overall the car runs pretty well minus pretty bad gas mileage.
Occasionally at the start the car will feel sluggish and I would have to put in a bit of gas not to stall.
No CELs
Rev limit at ~6800 (stock should be about 7400).
VTEC engages throughout post 4,900rpm (stock should be around 5,500 I believe).
These are the symptoms under normal driving conditions. I don't beat the car, I don't exceed 80mph and the car's warmed up as I endure these issues. Oil level is fine and speedo/tach isn't off ect...ect...
Has anyone experienced the same issues as me and figured it out? I know it could be several things... I'm trying to find another ecu as we speak. Someone (in the lude forum) said bad timing... but I am wondering if the car will even run that well if the timing is off... I wouldn't think so? So if you've endured what I'm going through let me know. Thanks
Old Jun 6, 2008 | 01:01 PM
Lou_EM1's Avatar
Default Re: H22 Low Rev Limit (Lou_EM1)
ttt
Old Jun 7, 2008 | 03:59 PM
Lou_EM1's Avatar
ttt
Old Jun 7, 2008 | 04:21 PM
oneludesol's Avatar
GDD's Dr. Phil?
Community Builder
stock jdm h22 gets vtec at 4800 and redlines at 6800.
Old Jun 7, 2008 | 05:45 PM
Lou_EM1's Avatar
Default Re: H22 Low Rev Limit (oneludesol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oneludesol &raquo;</TD></TR><TR><TD CLASS="quote">stock jdm h22 gets vtec at 4800 and redlines at 6800. </TD></TR></TABLE>
You're probably wrong.
Not 100% sure on the vtec x-over, but I'm sure all h22s redline at 7200 and limit at 7400-7600. So my limit is about 800 lower on an accurate tach.
Old Jun 7, 2008 | 08:01 PM
H22Ej1's Avatar
Shenanigans
your p13 is usdm from an obd1 prelude which has a redline of 6800 and vtec crossover at 4900 or something like that
Old Jun 7, 2008 | 08:14 PM
Lou_EM1's Avatar
Default Re: H22 Low Rev Limit (H22Ej1)
edit: I don't think you're right.
http://honda-portal.com/honda-..._id=6
Modified by Lou_EM1 at 9:21 PM 6/7/2008
Old Jun 7, 2008 | 08:20 PM
H22Ej1's Avatar
Shenanigans
visual differences im not really sure, but theres some pictures on this link of a jdm p13 if that helps u
http://www.preludepower.com/fo...60246?
also you realize that the jdm version has a speed limiter at like 113 or something
have you thought about other ecus such as the p28 or the p72 and getting it chipped/tuned
Old Jun 7, 2008 | 08:23 PM
Lou_EM1's Avatar
The motor is pretty stock and I'm planning on keeping it that way. And I have no intentions on going past 113... or past 80 for that matter.
Up because I think the only H series that redlines near what I am is a non-vtec. But obviously I have vtec motor and ecu.
Old Jun 7, 2008 | 08:29 PM
H22Ej1's Avatar
Shenanigans
chipping your ecu on your usdm p13 may be easier/cheaper than looking for a jdm one
if you really want a jdm one id search reputable dealers, and maybe ebay if your desprate
Old Jun 7, 2008 | 08:31 PM
Lou_EM1's Avatar
I edited my post, I don't think you're correct in thinking that I have a usdm ecu. I think all P13s should be going to 7400 rpms without problems.
Old Jun 7, 2008 | 08:44 PM
H22Ej1's Avatar
Shenanigans
swap it out with someone elses ecu may be an ecu deal, maybe ur tach is off by 500rpm or so, i know my stock one has always been way off
warrenbee
Aug 7, 2014 05:06 PM
Lou_EM1
Jun 5, 2008 03:05 PM
JasonST
Aug 29, 2006 03:02 PM
samsteinf22a
May 20, 2004 09:19 PM
explosive
Aug 14, 2003 02:56 PM
