Crank Pulley bolt: WTF?
Old Jun 5, 2008 | 08:25 PM
civicdelsol33's Avatar
Default Crank Pulley bolt: WTF?
Okay I have tried everything. Broke a 1/2inch ratchet with a huge pipe on the end, break bar wont budge it, 1/2 inimpact didnt do it. Now Im using a 3/4in 1300 ft/lb max torque impact wrench. Even cranked the psi to 110. It still wont f--king budge! What do I do? Just drive me car till my timing belt snaps and replace the motor?
I have tried everything. Im gonna go fix whats wrong with my exhaust, change my oil, and come back. If nothing, then I will give up. Mind u im at 230k and I really needed to change my Water pump, t belt and tensioner. Please help!
Old Jun 5, 2008 | 08:30 PM
4doorek96's Avatar
Default Re: Crank Pulley bolt: WTF? (civicdelsol33)
umm i had a prob like this once and i took the starter off and had a friend use a long screw driver to keep the engine from spinning and it worked (after two 1/2 in ratchets) also dont give up if that doesnt work heat will i know you can pick up those mini torches at autozone for like ten bcks good luck let us know how it goes
cherroneballs's Avatar
spray some pb blaster on it and let it soak in and try again? good luck.
zdizzle's Avatar
have used any bolt breaking products like dwd-40 if nut give it a try, b careful not to strip it out
Old Jun 5, 2008 | 08:35 PM
topless's Avatar
I had to heat my bolt with a mapp gas torch and then use a 4 foot cheater pipe on a breaker bar and a chock in the flywheel
Old Jun 5, 2008 | 08:37 PM
OMFG! IT IS A MIRACLE!!!!!! I DID IT!!!6 [freak]ING MONTHS AND I DID IT!!!! dIDNT NEED ANY BLASTER OR WD40. AND I USED CHAIN VICE GRIPS TO KEEP IT STILL WHERE THE POWER STEERING BELT ATTACHES AND IT HELD IT STILL JUST FINE. 1300/FT LB IMPACT FTMFW! [freak] THE DIRECTIONS. JUST CRANK THAT BITCH TO 110 PSI AND IT WILL WORK.
Old Jun 5, 2008 | 08:50 PM
topless's Avatar
Good for you. I'm sure you're pumped now. I know i was when i had the same problem back in feb.
Old Jun 5, 2008 | 08:53 PM
JRTegman987's Avatar
Default Re: (civicdelsol33)
mine was abitch had the block out of the car and couldnt get that bitch off
was taking a Snap on TNT impact gun to it on full pressure just kept beating it with that in both directions eventually it came off like an hour later
Old Jun 5, 2008 | 10:14 PM
slacks's Avatar
Default Re: (JRTegman987)
how about using a crank pulley holder?
it's well worth it to have lying around
or
i have that one ^^^ but doesn't work on SOME motors
Old Jun 5, 2008 | 10:46 PM
2004es2's Avatar
Default Re: (slacks)
Yup I have the black one too and it makes life much much better. The best 20 bucks I have ever spent. And it works with almost all honda motors.
Old Jun 6, 2008 | 03:04 PM
Yea I bought the black one because everyone told me it will work, and it didn't on my 93 Del Sol Si. I was pissed. With the 3/4 in impact, I could hold it still with my hand and bust it free. I would like to have the first one too, but it must be a new tool because I couldnt find it a year ago, except from Honda which never arrived.
3/4 in impact at 110 psi and chain vice grips own, because its a one size fits all.
Old Jun 6, 2008 | 03:05 PM
Yep same story here. I bet a 1 inch industrial would own though, but I dont think my compressor could handle it. It can barely keep up now.
Old Jun 6, 2008 | 06:11 PM
mouab18c1's Avatar
ahaha i just took mine to the tire shop and had em gun it off...free of charge
Old Jun 8, 2008 | 08:10 AM
kojack_0's Avatar
Default Re: (mouab18c1)
i used two of the scissor jack hook thing.
and a breaker bar FTW!!!!
Old Jun 8, 2008 | 01:41 PM
97ej6dx's Avatar
Default Re: (kojack_0)
Mine was crazy hard i put mine in gear and pulled my ebrake and it was on so tight it drug the back wheels!!! lol i ended up doin the same thing some wd 40 and an impact
Gibby1985
Sep 23, 2013 04:09 PM
092eg6
44
Mar 6, 2011 07:25 PM
raidacaipo
11
Jul 15, 2010 05:11 PM
h-o-n-d-a
12
May 10, 2010 05:38 AM
urb
May 27, 2005 04:46 PM
