input shaft bearing
The sound of a bad input shaft bearing usually will go away when the depressing the clutch pedal, because you are taking the load off of the bearing. My input shaft bearing is starting to go, and it sounds somewhat like a humming noise when the car is sitting in neutral. Im sure it can make a lot of different sounds depending on the condition of the bearing.
ether.real
Oct 7, 2009 06:49 PM
Pbanto
Apr 8, 2009 05:07 AM
pinky5
Nov 12, 2007 04:10 AM
