ef with b16a ignition timing
Old Jun 5, 2008 | 06:37 PM
vinEyFB16A's Avatar
Default ef with b16a ignition timing
what service pins needed to be jumped, and on what connector to set timing?? searched hardcore found nothing
Old Jun 5, 2008 | 07:35 PM
black0hatch's Avatar
Default Re: ef with b16a ignition timing (vinEyFB16A)
theres a little 2 wire plug on the passenger side up under the glove box on the side. most ive seen were blue plugs.
Old Jun 5, 2008 | 07:50 PM
zrickety's Avatar
Default Re: ef with b16a ignition timing (black0hatch)
same connector as your stock motor, if i'm not mistaken. mine was near the blower under the glovebox. i jumpered it and the CEL came on, so i knew it was jumped...set your timing, turn off the car and remove the jumper...check engine light goes out and you're good to go
Old Jun 6, 2008 | 06:20 PM
vinEyFB16A's Avatar
Default Re: ef with b16a ignition timing (zrickety)
aight thanks guys.
traxxasx
Mar 7, 2008 05:01 PM
type Gendy
May 18, 2003 02:53 PM
Jockobo
Mar 19, 2003 04:49 PM
