civic air box on a gsr motor
Old Jun 5, 2008 | 03:33 PM
Teglessb18's Avatar
Default civic air box on a gsr motor
Will it reduce air flow and then reduce the power of a gsr motor if I put a civic air box on it? The reason I ask is I have a gsr swapped civic and the I have a civic air box that I want to throw on. Thanks
Old Jun 5, 2008 | 03:34 PM
raidacaipo's Avatar
Default Re: civic air box on a gsr motor (Teglessb18)
I dont think its gonna fit.. unless it was an ex air box or something. What year is ur civic?
Old Jun 5, 2008 | 03:58 PM
Teglessb18's Avatar
Default Re: civic air box on a gsr motor (raidacaipo)
99 and it is an ex air box
Old Jun 5, 2008 | 04:26 PM
raidacaipo's Avatar
hrmmm.. I will fit but I believe you will have to squeeze the hell out of the plastic arm to make it fit in the box.
Old Jun 5, 2008 | 04:29 PM
Teglessb18's Avatar
ya but will it reduce air flow? It fits fine. It might be out of an si
Teglessb18's Avatar
is there any difference in the si and ex air boxes?
Old Jun 5, 2008 | 04:51 PM
raidacaipo's Avatar
I dont really know but I believe there is.. since the d16y8 manifold is slightly less powerful then the b16a2 therefore I beleieve the airboxes should be a lil different or larger for the si. but if it looks fine with the ex box then I say keep it..
Old Jun 7, 2008 | 06:32 AM
Teglessb18's Avatar
Ya I have an intake on it now and I will just put on the air box and see if i notice the car acting different or a difference in performance, Then I will decide if I should keep it on. Thanks for your help.
Anyone else know anything about this?
Old Jun 7, 2008 | 06:51 AM
pdiggitydogg's Avatar
I dont see how it would be any less. The filter may have a little less surface area, but the tubing is the same, and the flow requirement cant be any different for the b16a and the b18c.
(if you didnt know, the ej8 and the em1 have the exact same intake box, hence my comparison)
edit**
Now that I think about it, there is a euro civic with a b18c, that has the same intake as well. No, I cant remember the exact model, but the intake parts are the same.
You will be fine.
I will, however, recommend you use a K&N drop-in filter...
Old Jun 11, 2008 | 03:57 PM
Teglessb18's Avatar
Default Re: (pdiggitydogg)
Yes I have a drop in filter. Thanks for the info. Im going to put it in this weekend.
Old Jun 11, 2008 | 04:38 PM
97Ej6mike's Avatar
Either way, a Box is getting more flow (from my own epxeriences) than a cone filter on certain applications. Has to do with area and volume.
Old Jun 12, 2008 | 07:31 PM
Teglessb18's Avatar
Default Re: (97Ej6mike)
thats good to know.
roycivic92
Aug 21, 2009 01:42 PM
whitepandaeg6
Sep 17, 2007 10:20 PM
