NEw ProBlem...HELP
Old Jun 4, 2008 | 11:37 PM
sleepa's Avatar
Default NEw ProBlem...HELP
OK i have a crx with the d16z6 swap but with a bad alternator. i guess its one autozone's after market. i dunno it came like that wen i bought the car. i remove the 2 bolts and the sensor. but then i realized that it was too big to remove from the top..i tried jacking the car up and removing it from the bottom.it gets caught where the oil filter and the axles.tried twisting and turning but still couldnt get the alternator out the engine bay..so what now>?? if anyone have had this problem in the past..any help would be much appreciated.
Old Jun 5, 2008 | 09:47 AM
MIGPA26's Avatar
Default Re: NEw ProBlem...HELP (sleepa)
I had a 90 crx I would take the air intake out and run it out thru the left side, move all the hose on the left side and a little tweeking and should come out.
Also Im being told you have to take out the left axle, again im being told that I never had to do personally.
Now I have a 91 civic hatch si with a b16 swap, I just replaced the alternator yesterday. I had to remove the fuel rail, and it came out on the right side. Was very snug but came out then put a bigger one in there and boy oh boy that was hard to put in. Then after I did that the bottom hole was missed aligned. I had to take it out and go hit the hole straight. Took a total of about 2 hrs from start to finish.
Just have patients and you should be able to do it... Hope info helps...
Old Jun 5, 2008 | 11:08 AM
bobjohnson's Avatar
Default Re: NEw ProBlem...HELP (MIGPA26)
if you jack the car up so the wheel is off the ground, it WILL fit out through there. I did it with mine, took about 30 minutes to get the old one out and the new one in.
Old Jun 5, 2008 | 12:32 PM
thesmogman's Avatar
Default Re: NEw ProBlem...HELP (bobjohnson)
Yes! You gotta get the drivers wheel off the ground. Also if I remember right I removed the lower alt bracket too. Might be your hold-up.
Took me an hour to work out this puzzle the first time.
Also the brackets are the ground connection for the alt so clean them up good.
Old Jun 5, 2008 | 02:09 PM
Janos Lin's Avatar
Default Re: NEw ProBlem...HELP (thesmogman)
if you've removed your intake manifold brace at some point you could pass it under that and take it out from the passenger side between the manifold and the transmission.
Janos
Old Jun 5, 2008 | 08:41 PM
MIGPA26's Avatar
Default Re: NEw ProBlem...HELP (Janos Lin)
yep Janos, thats what I did. But didnt have to remove the bracket..
Old Jun 5, 2008 | 09:26 PM
Loaded Butane's Avatar
Ive done it by pulling the master cylinder and removing it through the top. Its only 2 bolts and easy as pie.
Old Jun 6, 2008 | 11:18 AM
MIGPA26's Avatar
Default Re: (Loaded Butane)
did you have to bleed the brakes after,
Old Jun 6, 2008 | 12:05 PM
Default Re: (MIGPA26)
Nope I didnt disconnect the lines.
katy purry
22
Dec 3, 2015 10:08 PM
GavinJuice
Classic Hondas
Feb 21, 2009 04:37 AM
legendaryr56
Aug 12, 2006 08:07 AM
fu*kfaceC1EH2
Jan 8, 2004 04:56 PM
djay86
Oct 2, 2002 04:23 PM
