Time to replace the clutch...any pitfalls I should look out for?
Old Jul 16, 2002 | 04:59 PM
RacerMike's Avatar
Default Time to replace the clutch...any pitfalls I should look out for?
Never done it before. I will have access to a lift and every tool I may need. Any peculiarities in doing the job I need to be aware of?
Thanks,
Mike
Old Jul 16, 2002 | 05:17 PM
ragejed's Avatar
Default Re: Time to replace the clutch...any pitfalls I should look out for? (RacerMike)
Torque wrench. No cheap way with the impact wrench...im still worried about when i got mine installed at acura...he used an impart on everything else...prolly the flywheel and clutch to
Old Jul 16, 2002 | 06:44 PM
eh-D's Avatar
Default Re: Time to replace the clutch...any pitfalls I should look out for? (ragejed)
It's a pretty big job, I've done 2 and the second one we dropped the tranny and had the flywheel off in two hours. It went back in after about 3 hours. That is without a lift.
The first one I did took like 12 hours to get the flywheel out and another 8+ to get it back in.
It's ok to use airtools to take it apart, and maybe run the bolts back(always start the bolts by hand) in but final torque specs should be left to a good torque wrench.
Old Jul 16, 2002 | 06:47 PM
ITR21's Avatar
Default Re: Time to replace the clutch...any pitfalls I should look out for? (eh-D)
u dont really have to torque honda clutchs but i would to be safe.
Old Jul 16, 2002 | 06:50 PM
Weston's Avatar
I may be in need of a clutch, so I'm wondering the same thing... Is it a pretty straight forward job? And what's this I hear about resurfacing the flywheel? Is that needed?
Old Jul 17, 2002 | 11:14 AM
ndustryalGSR's Avatar
Default Re: Time to replace the clutch...any pitfalls I should look out for? (Weston)
I just did my new clutch and flywheel last month. The procedure is very straight-forward -- no black magic here. BUT, there are lots of little things you have to do (i.e. make sure to disconnect ALL sensors, clips, wires, and tabs). Getting the axles out can be a pain, but if you have an air hammer, it should be a piece of cake (we had one -- it took 5 seconds). Also, if you have it on a lift, be sure to support the tranny fully, as it's pretty heavy and akward, and you don't want it accidentally crashing to the ground. Best advice: take it slow and easy, and be very thorough.
Post up or e-mail if you have any questions during the install.
Jk_DC2
Feb 17, 2009 10:40 AM
GSR_hatch936
10
Nov 2, 2007 03:15 PM
akasen8
Mar 26, 2004 08:02 PM
redrex91
Jul 18, 2003 03:05 PM
