brakes
hey everyone im new to this site... i have a 90 ef and i bought a complete brake swap off of a 91 CRX. how i am trying to figger out if this brake swap is going to bolt right up and is there anything that im going to need to buy for this swap...
thx guys
thx guys
if you want to convert to the complete si brake conversion you may want to get the 7/8 master cylinder and i believe the 2040 prop valve. not quite sure about the prop valve but the front should line up with no problem since they are both civics.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSR CRX »</TD></TR><TR><TD CLASS="quote">if you want to convert to the complete si brake conversion you may want to get the 7/8 master cylinder and i believe the 2040 prop valve. not quite sure about the prop valve but the front should line up with no problem since they are both civics.</TD></TR></TABLE> isnt it 40/40????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrpedro »</TD></TR><TR><TD CLASS="quote"> isnt it 40/40????
the 4040 is from the integra because thats where i got mine from when i converted to da specs. not quite sure about the si though.
</TD></TR></TABLE>the 4040 is from the integra because thats where i got mine from when i converted to da specs. not quite sure about the si though.
pnapolitano29
Nov 26, 2014 08:58 PM
88SeeOurEx
11
Oct 28, 2008 02:13 PM
