Problems with my tranny/clutch...help
Old Jun 4, 2008 | 09:36 PM
JDMproblem's Avatar
Default Problems with my tranny/clutch...help
Refer to link below..its really confusing
http://www.vancouvercivics.com...75947
key things: new tranny, new clutch, axles are in! car was drivable
Old Jun 5, 2008 | 08:54 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Problems with my tranny/clutch...help (JDMproblem)
double check that your axles are FULLY seated in trans
Old Jun 5, 2008 | 06:17 PM
JDMproblem's Avatar
thery are but I should be gettin some new axles soon
Old Jun 6, 2008 | 10:55 AM
94CivicSi's Avatar
The car drove ok for 1.5Kms?
What torque specs did you use for the flywheel and pressure plate bolts? If a PP flywheel bolt were to back out, the clutch disc would not sit against the flywheel. If the PP bolts came loose, it would not be able to hold the clutch against the flywheel.
Pull the starter, spin the motor by hand and check to make sure all those PP bolts are in and tight.
Old Jun 9, 2008 | 06:29 PM
JDMproblem's Avatar
Default Re: (94CivicSi)
Ive done that already and they are all tight..everything is good so far, ive taken off the clutch and the springs wer really wobbly and loose..so I replaced that and now it does the same thing except its the axle c-clip thats preventing the axle from going all the way in..So basically the axle isnt seated properly. What do you think could have caused the cltch to be in such a condition?
fwdlooser93eg
Jul 24, 2006 06:52 PM
ApolloSpeed
Feb 12, 2006 01:07 PM
flip1199
Nov 7, 2005 11:07 AM
type autox
Nov 22, 2001 11:57 AM
