b20b issue
Old Jun 4, 2008 | 08:11 PM
jdm-ek-si's Avatar
Default b20b issue
i am currently running a b20b i guess low compression bolted to a si tranny with ls intake manny and ls obd2 ecu mods= intake, fuel pressure regulator with Gage, stock headers with exhaust from headers back
the problem is when i take off i feel like im missing my low end torque doesn't really move tell like 3,500 rpm im supposed to have alot of low end torque right?
thanks for the help to you
Old Jun 5, 2008 | 05:34 AM
jdm-ek-si's Avatar
Default Re: b20b issue (jdm-ek-si)
bump ^^^^^^^^^^^^^
Old Jun 5, 2008 | 08:26 AM
acydphryck's Avatar
let's see here...it's a stock motor running with higher fuel pressure, no head work, no cams, stock header, stock exhaust with an intake, non-vtec cylinder head running on a stock air/fuel map on an OBD2 ecu...uh yea...you need to dump more $$$ into that setup to get that a little faster.
do the following and you MIGHT make close to 200whp:
replace stock non-vtec head with a GSR/B16/ITR cylinder head
port polish the head
install after market valvetrain
install stage 2 cams (Blox B or skunk2 stage2)
install ITR intake manifold or JG Victor X manifold
install 68mm/70mm throttle body
RC Injectors (310cc or 370cc)
fuel pressure gauge and regulator
after market cam gears (skunk2 or BDL)
stock fuel rail will work fine
install a walbro 190 or 255 lph fuel pump
install LS/VTEC oil line kit for the cylinder head
tune motor on hondata S200 or S300...maybe crome
that should give you a good start towards 200 whp
*EDIT* ditch the header and exhaust setup for 2.5" piping and RMF/SMS/Hytec header setup
Modified by acydphryck at 9:42 AM 6/5/2008
Old Jun 7, 2008 | 08:45 PM
jdm-ek-si's Avatar
Default Re: b20b issue (acydphryck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acydphryck &raquo;</TD></TR><TR><TD CLASS="quote">let's see here...it's a stock motor running with higher fuel pressure, no head work, no cams, stock header, stock exhaust with an intake, non-vtec cylinder head running on a stock air/fuel map on an OBD2 ecu...uh yea...you need to dump more $$$ into that setup to get that a little faster.
Modified by acydphryck at 9:42 AM 6/5/2008</TD></TR></TABLE>
i dont mean to be an ******* but if u look at my post i know im not fast im running stock fuel pressuer it is jus laging like i have no power from 1000 to 3000 b20's are known for ther low end torque well right now im at the verge of bogging down
Old Jun 9, 2008 | 06:20 AM
acydphryck's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm-ek-si &raquo;</TD></TR><TR><TD CLASS="quote">
i dont mean to be an ******* but if u look at my post i know im not fast im running stock fuel pressuer it is jus laging like i have no power from 1000 to 3000 b20's are known for ther low end torque well right now im at the verge of bogging down</TD></TR></TABLE>
i suggest getting new spark plugs and wires. also, might wanna change out your distributor rotor and cap....check timing and get a valve adjustment...hope that helps out
Old Jun 9, 2008 | 02:50 PM
7601chexplicit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm-ek-si &raquo;</TD></TR><TR><TD CLASS="quote">i am currently running a b20b i guess low compression bolted to a si tranny with ls intake manny and ls obd2 ecu mods= intake, fuel pressure regulator with Gage, stock headers with exhaust from headers back
thanks for the help to you</TD></TR></TABLE>
i had a similar problem with my b20b and it ended up being my TPS sensor, now its back to the normal launching at 1500rpm any higher just spins
sixtodc2
Feb 11, 2007 08:47 PM
vtec25
Feb 9, 2005 10:40 AM
BoostedCivicSedan
Jan 26, 2005 10:31 AM
RTW DC2R
Jun 5, 2002 07:47 AM
