Lost Lug Nut Key
Old Jun 4, 2008 | 06:44 PM
TonyRomo's Avatar
Default Lost Lug Nut Key
I have set of McGard lugs on my car and i lost the key. I cant order a new one because i lost the id number. any idea how to remove them? someone told me to weld a nut on there or something but i dont want to ruin my blades.
Old Jun 8, 2008 | 02:51 PM
starchase's Avatar
Default Re: Lost Lug Nut Key (TonyRomo)
If you have an impact gun. You can get a lug removal kit. I know sears charge some money to removal them but forgot how much. The kit are not cheap either.
Old Jun 8, 2008 | 02:59 PM
JRSC01GS-R's Avatar
Default Re: Lost Lug Nut Key (starchase)
most tire shops can get these off for u, but be prepared to pay
Old Jun 8, 2008 | 03:30 PM
g3Gsr443's Avatar
thought i lost my key, i was told torch and a hammer if you feel lucky, but then found it.
Old Jun 9, 2008 | 04:25 AM
matgee's Avatar
they make a socket called a Easy out, all it does is uses a reverse thread, so it will chew the crap out of your lugs, but atleast you'll be able to get them off, then replace your lugs
Old Jun 12, 2008 | 11:55 AM
sjbmx's Avatar
take a socket (the kind with all the little teeth) thats just a bit to small to fit it over the lug and hammer it on then use that to remove it. OR if you have an hour or so to kill id just carve/file/dremel out a new key
blaze.1
Oct 5, 2009 05:51 AM
Homotor
Feb 20, 2009 12:29 PM
94hatchvx
Jul 14, 2007 10:22 PM
billyhoe
May 18, 2005 02:23 PM
shooitzlinh
Mar 20, 2005 06:44 PM
