SRS Light ON After Cluster Switch ... No Air Bags
Old Jun 4, 2008 | 05:29 PM
janvitos's Avatar
Default SRS Light ON After Cluster Switch ... No Air Bags
I don't believe this has been covered before.
I have a Honda Civic 1995 4 Doors with no SRS system.
I just switched the cluster from another 1995 Civic to have the integrated tach.
Though, this cluster has an SRS light and it is always ON.
I've read many threads about resetting the SRS light but i don't have any SRS system in my car.
I was wondering if there's a way to reset the SRS light directly at the cluster or something of the sort.
Thanks.
Old Jun 4, 2008 | 05:38 PM
EquipedWithVtec's Avatar
Default Re: SRS Light ON After Cluster Switch ... No Air Bags (janvitos)
IF you do not have an srs airbag system or w.e its called just look on the back and take out the bulb to the srs light ALSO i do have an srs airbag and mine is on and same with the previous civic i had both in no accidents and it passed inspection fine no questions about it so if you dont have it just take out the bulb
Old Jun 4, 2008 | 05:49 PM
janvitos's Avatar
I guess i have no choice.
Thanks for the info !
Old Jun 4, 2008 | 06:55 PM
janvitos's Avatar
Got it.
If anyone ever runs in to this problem, here is the solution.
1. Remove the transparant cover from the cluster.
2. In the bottom-center of the back of the cluster, find a white plastic clip. This clip holds the SRS Light Casing in place.
3. Push on the plastic clip, so the casing is pushing on the speedo and tach gauges gently, until the SRS Light is relvealed, on the front side.
4. Remove the SRS Light.
To the contrary of other people, i was able to remove the light without disassembling any needles or gauges. Simply be gentle when pushing the casing so it doesn't crack or break the plastic gauges.
Old Jun 5, 2008 | 05:56 AM
IanB's Avatar
Here's an easier way: on the back of the cluster, unplug the yellow harness. That's it, no more SRS light.
TimM888GT
Jan 29, 2015 08:42 AM
WiedemannC
Honda Civic (2001 - 2005)
Oct 22, 2010 04:33 AM
CeeJayy
Aug 25, 2007 09:06 PM
Dc2 Powered
Aug 1, 2004 02:33 AM
.jacob
Jan 31, 2003 07:35 AM
