FS: GARAGE/MOVING SALE! 99 GSR head, 98 GSR block, 97 LS parts, EG hatch trunk cover, OEM HG
i have many parts to get rid of this month due to moving. i don't need everything and would prefer not to move it all.
please help me out!! below is the list. i can ship anything at buyers expense. if you're local then i can meet you somewhere. i have pics of everything that i can send you, just provide an email address when you PM me. I AM LOCATED IN PA. <U>IF YOU DON'T LIKE THE PRICE, THEN THROW ME A REASONABLE OFFER!</U>
<U>HEAD IS SOLD!!</U>
99 GSR head--complete head minus cams. DOES NOT include IM, TB, Injectors, Fuel Rail or Dist. alot of work was done to this head and it's a great deal! i have had this head for approx 3 years now. it was originally for my GF, who is now my ex-GF. i already have a similar head in my Civic... so i really don't need this one! below is what has been done:
60k original miles before rebuild. moderately ported (both Intake and Exhaust), polished Exhaust ports, deshrouded valves, polished combustion chamber, NEW ITR outer springs (all 16), NEW Portflow inner springs (all 16), NEW OEM valvestem seals, OEM valves reseated, milled .005", fully assembled and cleaned. all sensors still on the head and working. all work was done by a local reputable machine shop who has done quite a few Honda heads/blocks. i am currently using the same setup on my B16. only difference is the head i am using now is not ported as much. it makes good power! ---> (B16 block w/GSR head, crap header, exhaust, basic intake, Skunk tuner 1 cams=170 WHP by Evans Tuning) for the parts alone i spent over $850 (not including all the work done, which is another $600). i am taking a loss on this but it has to go!! <U>this head is fully assmbled and ready to go, it has not been used since all the work was done. just bolt it on, throw in some aggressive cams, and you're ready to go!</U> <U>$800 OR BEST REASONABLE OFFER</U>
<U>BLOCK IS SOLD!</U> 98 GSR block--complete minus the crank, rods and pistons which have been sold. no damage at all to the block or it's parts, except one sensor is cracked. very low miles, about 70K. still 81mm bore with no cracks in the sleeves etc. <U>$280</U>
NEW OEM B18C Headgasket--$60 OR $40 when you buy the above 99 GSR head OR 98 GSR block
<U>SOLD!</U> EG Civic Hatch Cover, Black--a little worn but no damage--$50
<U>SOLD!</U> DOHC VTEC valvecover--stripped and cut for gears--$45
<U>SOLD!</U> RYOBI Dremel tool set--brand new in the package and never opened or used, very nice set w/case, includes many attachments and bits, with 24" flex shaft too, 228 piece set, digital speed control w/display.--$50
Rockford Fosgate (spelling?) Amp--2 channel bridgeable, 400W RMS bridged w/bass control, used lightly for about 3 years to power the 12" sub below, originally paid about $325 for it new and it still works perfectly! i have the original packaging w/everything. the top logo area of the amp is scratched from when my sub box moved and rubbed on it. only cosmetic though. ask me for the model # etc. --$140
Visonik 12" high excursion sub--300W RMS, perfect condition, sounds great, used lightly (rock music), includes small custom sealed box. sub was $130 and box cost about $40 to make.--$65 <U>if you want the sub and amp i'll give a package deal since they work great together! i removed the amp and sub for weight reduction, plus i need $$$ soon!</U>
97 LS parts, Green Exterior & Tan Interior--just make reasonable offers:
rear trunk wing
ABS unit
complete steering wheel, airbag, steering rack assembly
Automatic Tranny w/starter
Front seats, no major damage
console sections
door panels
glovebox
passenger airbag
power steering pump
AC pump
radiator (Automatic)
ECU
Dist
throttle body (no TPS)
misc. sensors pulled from throughout the car
there are more LS parts, i just can't think of them all right now.
ask me if there is something you're looking for!
Modified by sweet at 1:59 PM 6/22/2008
please help me out!! below is the list. i can ship anything at buyers expense. if you're local then i can meet you somewhere. i have pics of everything that i can send you, just provide an email address when you PM me. I AM LOCATED IN PA. <U>IF YOU DON'T LIKE THE PRICE, THEN THROW ME A REASONABLE OFFER!</U><U>HEAD IS SOLD!!</U>
99 GSR head--complete head minus cams. DOES NOT include IM, TB, Injectors, Fuel Rail or Dist. alot of work was done to this head and it's a great deal! i have had this head for approx 3 years now. it was originally for my GF, who is now my ex-GF. i already have a similar head in my Civic... so i really don't need this one! below is what has been done:60k original miles before rebuild. moderately ported (both Intake and Exhaust), polished Exhaust ports, deshrouded valves, polished combustion chamber, NEW ITR outer springs (all 16), NEW Portflow inner springs (all 16), NEW OEM valvestem seals, OEM valves reseated, milled .005", fully assembled and cleaned. all sensors still on the head and working. all work was done by a local reputable machine shop who has done quite a few Honda heads/blocks. i am currently using the same setup on my B16. only difference is the head i am using now is not ported as much. it makes good power! ---> (B16 block w/GSR head, crap header, exhaust, basic intake, Skunk tuner 1 cams=170 WHP by Evans Tuning) for the parts alone i spent over $850 (not including all the work done, which is another $600). i am taking a loss on this but it has to go!! <U>this head is fully assmbled and ready to go, it has not been used since all the work was done. just bolt it on, throw in some aggressive cams, and you're ready to go!</U> <U>$800 OR BEST REASONABLE OFFER</U>
rear trunk wing
ABS unit
console sections
door panels
glovebox
passenger airbag
power steering pump
AC pump
ECU
Dist
