4.4 FINAL DRIVE to 4.26 from LS into a Y21 PLEASE HELP!!!! Searched!!!!
Old Jun 4, 2008 | 04:08 PM
crazy_eddy's Avatar
Default 4.4 FINAL DRIVE to 4.26 from LS into a Y21 PLEASE HELP!!!! Searched!!!!
Hi Tranny profis
I have a 1994 Civic SIR With a b16a2 and the Y21 Tranny and 4.4 Final D. I doing a lot of Highway driving and want to make my gears longer.
So what i bought is the 4th and 5th gear from the JDM Integra Type-R S80 tranny which are longer gears than my Y21 tranny. I have no LSD
I also found a LS final drive 62 totth 4.26 FD i would like to swap that too so that all my gears are a bit longer. I have a Turbo engine
I searched all over the internet but no one ever did that. My question is when i swap the Final drive gear over to the LS will i also need the counthershaft from the LS to make it all work?
Hope someone can give me some answer.
Thanks
Old Jun 5, 2008 | 09:00 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: 4.4 FINAL DRIVE to 4.26 from LS into a Y21 PLEASE HELP!!!! Searched!!!! (crazy_eddy)
final drive units consist of the counter shaft and ring gear(need to stay together)....so, yes, you would need the LS counter shaft and ring gear. I personally have not done such a swap, but you shouldn't have any problems
Old Jun 5, 2008 | 05:06 PM
NJIN BUILDR's Avatar
Default Re: 4.4 FINAL DRIVE to 4.26 from LS into a Y21 PLEASE HELP!!!! Searched!!!! (Evs-One)
I switch from a straight up gsr in my ls turbo to a late cable ls (ys1) in a gsr case with a late hydro fifth and a b16 ring gear and gsr c'shaft (4.40 final.It knocked about 600 rpm off at seventy mph.It made a huge difference.I think the ls final in a b16 would be a real dog.I would just do the fourth and fifth and keep your b16 final.Check out a couple of the gearing calculators and play around.
Old Jun 5, 2008 | 07:07 PM
crazy_eddy's Avatar
@njin buildr
Yea i checked some gearing calculator and i will stick with just the 4th and 5th from a JDM ITR in a B16 trany and leave the 4.4 final the way it is
Old Jun 5, 2008 | 11:31 PM
Gearspeed-Performance's Avatar
Default Re: (crazy_eddy)
It is always good to keep the ring and pinion as a matched set. Doing anything different can spell disaster...remember that it is not only tooth count that matters...there is also gear pitch that can vary So never just go off of a tooth count....a different pitch from an improper gear mesh can destroy a transmission very fast!!
boosted_b16a2
Transmission & Drivetrain
Jan 16, 2011 04:37 PM
smoovy
12
Jul 15, 2009 12:14 PM
turbotime
May 2, 2006 10:15 PM
Race Egr
May 4, 2004 11:06 AM
