do the 1997 integra ls brake rotors need to be pressed on???
Old Jun 4, 2008 | 03:49 PM
dallison's Avatar
Default do the 1997 integra ls brake rotors need to be pressed on???
hello again, after having a tl, cl and rl, we have an integra to drive instead of the 4runner which is sitting in the garage.
we had a 95 accord that need to have the rotors pressed on and i am concerned about the brakes in this car. I know it is a stupid question, but before i dig into each corner and spend time under there, i need to know.
thanks
Old Jun 4, 2008 | 05:02 PM
dallison's Avatar
Default Re: do the 1997 integra ls brake rotors need to be pressed on??? (dallison)
or can you just take off the old ones after removing the screws?
Old Jun 4, 2008 | 05:21 PM
mayoforlife2's Avatar
no they arnt pressed just take the 2 holding screws out if they are still there and then take the rotor off , might need a hammer , dont hit the actually part of the rotor where the pads are unless you are replacing the rotors
Old Jun 4, 2008 | 05:31 PM
dallison's Avatar
Default Re: do the 1997 integra ls brake rotors need to be pressed on??? (mayoforlife2)
thanks, i wasnt sure about that. it was a pain in the *** with the accord to take off the whole suspension peice and have someone press it off.
Old Jun 4, 2008 | 06:13 PM
super jdm yo's Avatar
yeah you can get a impact screw driver and those screws should come right off.
Old Jun 4, 2008 | 06:18 PM
lsneo's Avatar
yea its easy with an impact driver, if not i can be a pain. Easy way for me was to put the right size screw driver on it and beat on it with a hammer a bit. Then it should be easier to take those screws off.
Sporty2222
Acura TL, RL & ZDX
May 21, 2007 02:10 PM
tubbie
Sep 15, 2006 05:30 PM
txwylde
Mar 22, 2005 04:35 PM
civic91
Apr 2, 2003 01:23 PM
Conechaser
Jun 30, 2001 03:41 AM
