uncommon vss issue after rebuild. (searched)
I have no speedometer reading nor vtec. of the 3 wires going on vss , the one that goes to ECU has continuity, the other two have ground continuity. I dont see the need for 2 grounds on one sensor. So If i rewire this, where do the other two goto? O and ive already swapped out a different vss and a different clip to....
