Grouchy First Gear
Old Jul 16, 2002 | 03:53 PM
Regular Series's Avatar
Default Grouchy First Gear
Have any other Teg owners here ever noticed that first gear doesn't always go in easily from a stop? Particularly when the gearbox is cold? Sometimes I have to try two or three times to get it to go. In case you're wondering - yes, I know how to operate a manual tranny; been at it for years. BTW, I have a 98 RS w/ 58k on the clock. I drive mostly highway miles. I have fresh (only 8 to 10k old) gearbox lube (Redline MTL) but got the same problem with the Honda lube. TIA
Old Jul 16, 2002 | 04:08 PM
Weston's Avatar
Default Re: Grouchy First Gear (risingson77)
Yeah, and reverse is the same way. It does it with both my short shifter and my stock shifter. Not a big problem, but definately an annoyance.
Old Jul 16, 2002 | 04:14 PM
Default Re: Grouchy First Gear (Weston)
Yeah, I do have a short shifter (forgot to mention it ). No difference either way, like you said.
I know that reverse is not synchronized...is it possible that first isn't either?
Old Jul 16, 2002 | 06:23 PM
ebelp's Avatar
I normally have to go down into 2nd gear and straight up into 1st when it gets stuck like that...
Old Jul 16, 2002 | 07:02 PM
ITR21's Avatar
Default Re: Grouchy First Gear (ebelp)
first and reverse are both hard to get into.....if it wont go into either just keep aplying pressure on it to go in and slllllllloooowwwly let out the clutch and it will go in.
Old Jul 16, 2002 | 08:05 PM
Thrillhouse's Avatar
Default Re: Grouchy First Gear (ITR21)
mine does the same thing i get pissed off when im sitting in traffic.
Old Jul 16, 2002 | 08:08 PM
Hairy Gorilla's Avatar
Default Re: Grouchy First Gear (Thrillhouse)
I am not exactly sure what it does, but my dad always pulls in into second then straight up to first when he drives a stick. (from a stop that is) I can ask him what that is for tomorrow...
Old Jul 16, 2002 | 08:11 PM
Adampops's Avatar
Default Re: Grouchy First Gear (TimmyMaryak)
I had this problem too, But im not sure, and i dont want to sound like a dumb ***, but i think it has something to do with the syncros (sp). I usually take the clutch out completely, then back in and try again, it works for both reverse and first.
Old Jul 16, 2002 | 09:02 PM
Comptech98GSR's Avatar
Default Re: Grouchy First Gear (Adampops)
yea that's what i do, and it works, it happens to me pretty regularly. Does it mean anything, anybody know?
Old Jul 16, 2002 | 09:09 PM
carl_aka_carlos's Avatar
Default Re: Grouchy First Gear (Comptech98GSR)
well, i think it may be some sort of lock out, have you ever tried putting you car into first at any speed above 20? ain't happenin'. all I have to do is release the clutch, the depress the clutch and it'll go in gear. but I dunno if that's what it is. if first wasn't sync'd you wouldn't be able to put it in gear if you were rolling backwards w/o some grindage
Old Jul 16, 2002 | 09:36 PM
Tweakmeister's Avatar
Default Re: Grouchy First Gear (carl_aka_carlos)
i've looked into this a bit.
there was someone somewhere who claimed to have cut the "block" that makes it so hard.
otherwise, the 2 to 1 trick or revving it up to anywhere from 4k to 6k will get it to go in (and clutch feathering...but be careful)
Old Jul 16, 2002 | 10:08 PM
Jesse H's Avatar
Default Re: Grouchy First Gear (Tweakmeister)
it's normal.
Reverse isn't synchronized, that's why sometimes it's hard to get it in gear (also why it makes that whirring noise). You can double clutch or shift into another gear to stop the shafts from spinning or line them up better, then back into reverse.
I'm not tranny guru but that's the gist of it.
I can't recall if first gear is also straight cut, but just being such a low gear, it's more difficult to engage. The same trick with double clutching helps it engage much smoother if you ever notice resistance. Rev matching also helps if you're at a crawl, say ~5mph. Just don't force it...that's ouch.
Old Jul 17, 2002 | 12:09 AM
bloobin's Avatar
i have a 98 RS teg with 60k and new fluid from 5k ago.. i also get stuborn 1st gears..
but it might be from my tranny being beat to ****.
Old Jul 17, 2002 | 02:37 AM
Cool, it's nice to know I'm not the only one.
I do double-clutch (like I should) when first gives me trouble...seems to work pretty well. Maybe that's what Vin was talking about.
I have heard something about a lockout on first, too. I don't see why they wouldn't just make it straight cut, but oh well - Honda's engineers probably know more about their cars than I do.
Old Jul 17, 2002 | 05:08 AM
maggsgsr's Avatar
Yea me too,my friends 2k GSR does it and so does my friends 95 and 97,I take its just the way most teg trannies are.
Old Jul 17, 2002 | 05:14 AM
GSRaCeRbOI's Avatar
mine does that in 1st and reverse.. if I let off the clutch and try again it usually goes in..
Old Jul 17, 2002 | 06:16 AM
Muckman's Avatar
Moderator in Chief
Default Re: Grouchy First Gear (GSRaCeRbOI)
I always had problems getting into 1st, sometimes even when at a dead stop. I used to always double clutch 1st and reverse. But then I noticed that if I went down into 2nd then into 1st it always slid right into 1st without any problems. Dunno why, maybe things were lined up better when coming from 2nd? But try that.
Old Jul 18, 2002 | 03:18 PM
Default Re: Grouchy First Gear (Muckman)
The 2-1 trick worked fine in my ten year old Tercel (but not so well in the Teg)...I don't think the gearbox hung up anywhere near as easily as the Teg.
LShatchie
18
Feb 24, 2006 08:00 PM
DC5SMunky
Aug 13, 2005 09:43 AM
h22pwr
Jun 7, 2005 11:33 AM
Toms96GSR
Jul 29, 2002 01:36 PM
Acura97GSR
Jun 29, 2001 07:39 AM
