Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
K&N V2 intake, whose got it?
Old Jun 4, 2008 | 09:32 AM
invisible's Avatar
Default K&N V2 intake, whose got it?
Im looking for a new shortram intake saw this new version of the K&N typhoon intake. Anybody have this? Dyno? A/F? Hesitation/bog? Heat soak?....etc.
Only picture I have found so far...
old
new:
Modified by invisible at 12:43 PM 6/4/2008
Old Jun 5, 2008 | 12:59 PM
06sik20z3's Avatar
Default Re: K&N V2 intake, whose got it? (invisible)
in for more information
Old Jun 7, 2008 | 08:30 PM
KlickityClack07's Avatar
Default Re: K&N V2 intake, whose got it? (06sik20z3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 06sik20z3 &raquo;</TD></TR><TR><TD CLASS="quote">in for more information</TD></TR></TABLE>
Same here.
I just pick up a K&N v1 for a good price tho.
Old Jun 7, 2008 | 09:45 PM
knaira112387's Avatar
looks good is that the short ram?
Old Jun 8, 2008 | 06:31 AM
FBP_Si's Avatar
Any dyno #'s from this new vertion. Looks good in that bay.
Old Jun 8, 2008 | 08:57 AM
Nsane's Avatar
i have a V1
use to make a weird noise on my FA5 (when i left off the throttle) but i put on my newer FG2 and it sounds as like it should no extra noises but i &lt;3 My K&n
Old Jun 8, 2008 | 03:29 PM
Greg50Lt's Avatar
i cut my v1 and made it fit better and changed the filter and it fits nice. i think it gave me a lil more down low too. going from the 5in round filter to the 3in round
Old Jun 9, 2008 | 04:33 PM
McBitchin's Avatar
Default Re: (Greg50Lt)
anybody know if you can fit the arc intake on the new si, I know they make one for the rsx-s, they look sick, ive seen them on the s2000 and they look it says you have to re route the ac lines but thats no big deal to me. sorry to highjack a bit, I'm still a newbzor.
Old Jun 18, 2008 | 09:34 PM
Default Re: (McBitchin)
Do you think heatwrap on the V1 would make a difference at all? I just picked up a used on from a guy on the 8th and it has heat wrap on it and im deciding weather or not to take it off. It dosent look preety but i think seems like a good idea.
Old Jun 18, 2008 | 09:37 PM
dirtySOHC's's Avatar
Default Re: (KlickityClack07)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KlickityClack07 &raquo;</TD></TR><TR><TD CLASS="quote">Do you think heatwrap on the V1 would make a difference at all? I just picked up a used on from a guy on the 8th and it has heat wrap on it and im deciding weather or not to take it off. It dosent look preety but i think seems like a good idea.</TD></TR></TABLE>
heat wrap is used to try and keep heat from escaping like say on a header to reduce bay temps. heat wrap on an intake only ampliefies the already hot air the intake is taking in.
heat wrap and intake = useless
EDIT: unless it's the type that looks like foil. that may help a bit. it does the opposite of heat wrap.
Old Jun 18, 2008 | 09:52 PM
Default Re: (dirtySOHC's)
I was looking at it and it has foil underneath the heatwrap.
Thanks for the info.
Old Jun 18, 2008 | 09:59 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KlickityClack07 &raquo;</TD></TR><TR><TD CLASS="quote">I was looking at it and it has foil underneath the heatwrap.
Thanks for the info.</TD></TR></TABLE>
kinda confused. so you have the foil type heat resistant wrap underneath some heat/header wrap?
that would defeat it's purpose (the heat resistant wrap)
Old Jun 19, 2008 | 07:05 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtySOHC’s &raquo;</TD></TR><TR><TD CLASS="quote">
that would defeat it's purpose (the heat resistant wrap)</TD></TR></TABLE>
I bought it used and the guy has foil, im not sure if its a special kind of foil, but it looks like just plain foil, underneath some heat wrap.
Sounded like a good idea but i wasnt really sure. I thought that heat wrap tried to keep heat out but its the opposite.
Ill be taking it off for sure now.
Old Jun 19, 2008 | 02:49 PM
ju5tchi11in's Avatar
The foil stuff much like aluminum does not conduct heat very well. In this case for its application, probably a good thing.
The foamy heat wrap acts as an insulator, i.e wrap your copper pipes so they do not freeze in winter. So take that part off.
Old Jun 19, 2008 | 04:00 PM
Default Re: (ju5tchi11in)
gonna take it all off. I want the polished look anyway. The heat wrap looks nasty.
Thanks for the help
patrickstar
15
Dec 16, 2007 06:36 AM
IntegraType-R
Dec 5, 2007 05:30 PM
VtecKiDD
46
Jul 13, 2006 08:43 AM
stRodda
Jan 11, 2006 01:20 PM
rough_draft
Mar 16, 2004 08:07 PM
