buddy club stage 4 cams + boost ?
i have a friend that built a slow n/a pile and im trying to talk him into boosting it. compression isnt that high but im having second thoughts about using the cams.
his n/a setup so far is:
b17block
usdm itr pistons (~10.5:1comp)
pr3 head with buddy club valves,valve springs, retainers and stage 4 cams.
info on the cams;
intake; 12.3mm lift 306' advertised duration (266 @ 1mm lift)
exhaust; 11.8mm lift 302' advertised duration (262 @ 1mm lift)
anyone ever use these cams with boost ? what exhaust mani would be best for this kind of setup ?
b17block
info on the cams;
wouldnt go with boost with those cams. earldasquirell had buddy club spec 3+ and was losing power since VTEC wouldnt engage untill 7500RPMs. The size of the low profile lobe is probably larger or the same size as a gsr's VTEC cam lobe. which is what he is running now and putting down 350whp and 220ish tq. with the gsr cams and running 12.5 in the quarter
