EDM Flush Mount CRX Spoiler
Does anyone know how to mount this to the hatch.
I am in the process of purchasing one and was told this:
"To mount the spoiler you have to drill 4 holes. It has 4 more pins for mounting but these are not included, and that would mean that you have to drill 8 holes in the hatch."
Can anyone elaborate...Thanks
All you need are the four holes to drill the wing in.
Some of my plastic peices (the other four holes) were jacked up so I removed those and the good ones that I had.
JG
JG
there are 4 mounting points on the bottom of the wing/spoiler. take a marker and mark the points then set the spoiler on the trunk this will leave a mark for each hole you need to drill.this is how i did it and it worked fine.
THANKS EVERYONE
I haven't purchased it yet cause i was sketched about having to drill eight holes in my hatch.
and it's not some aftermarket BS either, oem EDM from the Netherlands
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stevethecat »</TD></TR><TR><TD CLASS="quote">Use 3M Double sided tape thats what i do and i havent had any problems</TD></TR></TABLE>
I'm sure thieves must love that.
theives wouldn't know it's not bolted on anyway...
if you like it and want the EDM look, just drill the holes and mount the thing. use a little silicone or urethane at the studs so it doesn't leak. at least it's an OEM part!!
line up the spoiler and mark them. Once your satisfied drill through the marking points. Mount the spoiler and use a nut to tighten down the spoiler from the underside of your hatch (this will require you to remove the hatch interior.)
Your will need 4 nuts to hold it down. In case one or more is broken then I would recommend taking the other users method of mounting it on.
I bought a 90 CRX with the EDM spoiler, is there some sort of gasket that goes in between the spoiler and hatch? If so where can I find one or does the stock USDM CRX gasket work?
thehiddencheese
Honda Civic (2001 - 2005)
Nov 30, 2015 02:13 PM
