B16a block with a B17 head
i was wonrding if this set up is ok too use since the b17 bloxk is hte same has a b16 kinda right little different would it be safe to use it like this i mean is it a good set up
Both the B16 and B17 had PR3 heads. It will work. Check the stock rev limits to make sure your aren't going to exceed the valve train capability.
LS1Bait
Jan 11, 2009 04:08 PM
