tilton twin disk not full disengaging in first/second gear
i have a tilton twin disk w/ hydraulic throwout bearing and tilton master cylinder. sometimes when i'm coming to a stop and i'm in first or second gear [not in neutral] but i'm stepping on the clutch i feel the car jerking back as if it was still in gear. my assumption is that the clutch is not full disengaging. so i raised the clutch pedal and still doing it. i bled the line numerous times and it's still doing the same thing. this is also giving me problems getting into second gear at high rpms. when shifting at 9000rpm i have to basically step on the clutch and hold it briefly before i can pull it all the way into second gear or else it'll miss second. what could be causing this. should i switch it back to the fork and regular throwout bearing.
i'm pretty sure it's not the tranny since i never had this problem until i installed the twin disk.
are you sure you are not overstroking the clutch. It would give the symptoms you are talking about.
I have used the tilton throw out bearing on many cars with success,it just takes a little time to setup correctly. Some people would rather not deal with it, but it does work.
do you have a clutch stop on your pedal? i was having similiar problems with mine, and after a bunch of adjustments to the upper and lower clutch stops i got it perfect. im running a shaved oem tob for what its worth...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miller »</TD></TR><TR><TD CLASS="quote">are you sure you are not overstroking the clutch. It would give the symptoms you are talking about.
I have used the tilton throw out bearing on many cars with success,it just takes a little time to setup correctly. Some people would rather not deal with it, but it does work.</TD></TR></TABLE>
didnt one of yours leak and weld the plates together? im sure they work, i just think that it works great without it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtekthis »</TD></TR><TR><TD CLASS="quote">
yes sir it did, i was over-stroking itand it blewout the seal.
</TD></TR></TABLE>yes sir it did, i was over-stroking itand it blewout the seal.
yes sir it did, i was over-stroking itand it blewout the seal.</TD></TR></TABLE>
miller, i'll be stopping by the shop tomorrow or the next day cuz i gotta get my wastegate flange welded again, it has small hairline crack, so i'll bring the car with me and show it to you. thanks for the help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by building boost »</TD></TR><TR><TD CLASS="quote">so basically overstroking means i need to lower the pedal?</TD></TR></TABLE>pedal stop
yes sir
yes sir
FuNkDrSpOt
15
Oct 15, 2007 03:03 AM
ActiveAero
Feb 6, 2007 08:33 AM
