How to remove secondaries from GsR mani.?
Old Jul 16, 2002 | 02:59 PM
1 speedstar's Avatar
Default How to remove secondaries from GsR mani.?
anyone got a link or know exactly what to do? i searched but nothing came up. thanks
Old Jul 16, 2002 | 03:52 PM
b18cya's Avatar
Default Re: How to remove secondaries from GsR mani.? (A-Spec)
get a JG victorX or skunk2 IM
Old Jul 16, 2002 | 07:27 PM
kinesistech's Avatar
The center section is removable, but once you get everything out of it, you will need to make sure you plug the holes left fromt he axle for the butterflies. The manifold comes apart with 4 bolts. You may need new gaskets when you go back together.
Old Jul 16, 2002 | 07:53 PM
MikeSarr_GSR's Avatar
Default Re: How to remove secondaries from GsR mani.? (kinesistech)
wouldnt running the manifold without the butterfly plate make
flow dependent through all 8 runners? I have been told that this
increases turbulence and reduces the ability for the fuel to atomize
making this less than efficient setup. If you want to see what the
car feels like with it all the way open all you need to do is remove
the vaccum and the secondaries will slap open. Then, plug the
vaccum hose, drive it and see if you like it. Better yet, do this
on the dyno and get a before and after.
Ericks racing has a GSR all motor 11K rpm engine. They use the
stock GSR manifold WITH THE BUTTERFLIES. They opened the
secondaries to make upper end power you can see it here:
http://www.hondata.com/dynoericksracingrc.html
the crossover WHP/TQ at 5250 rpm is between 125/130 which
is strong and it makes peak of 268whp at 9900 rpm peak
TQ of 148 at 7900 through 9500 where it begins to fall off
to 120 at 10800rpm... would you say this IM is sufficient?
this is good for a 10.95 second run> i dont know if this motor
is in an integra or not, maybe a civic hatch who can tell
cheers
Old Jul 16, 2002 | 09:09 PM
t's Avatar
t
Default Re: How to remove secondaries from GsR mani.? (MikeSarr_GSR)
mkeacura
Aug 30, 2013 01:22 AM
twentyhurtz
Dec 18, 2008 06:21 AM
Ratman
11
Apr 20, 2005 11:39 PM
1fasEG
Nov 1, 2003 03:52 PM
hybrider
Apr 9, 2003 09:20 AM
