Clutch Install........
Old Jul 16, 2002 | 02:51 PM
Unsung's Avatar
Default Clutch Install........
Anyone have a step-by-step or website for a clutch how-to-install for B-series trannies? Thanks in advance.....
Old Jul 16, 2002 | 05:02 PM
poison's Avatar
Default Re: Clutch Install........ (JDM B-Series)
only thing i suggest is hayne's or helm's manual from a 99-00 Si or Del Sol VTEC manual if you have a hybrid.
Not that complicated, just need to support the Engine with a cherry picker, and drop the tranny to the ground with some support, then change out the clutch and such, and make sure that the flywheel is still completely flat, and/or turn it or get a better flywheel.
Old Jul 16, 2002 | 06:32 PM
BreakStuff's Avatar
New User
Default Re: Clutch Install........ (poison)
and make sure the clutch disc "slides" onto the tranny mainshaft splines easily when the trans is removed from the vehicle, its a bitch to find out you have tight splines while holding a tranny above yer head.. and also make sure to have the clutch disc aligned properly during installation, I personally use my finger, but a 12mm chrome Craftsmen deep well socket works wonders..
HeelToe
Jul 1, 2003 07:12 AM
Chaos69
May 17, 2003 01:12 PM
Jack Black
Apr 2, 2003 03:43 PM
hunterln
Sep 18, 2001 10:08 AM
