90 si rev limiter
Old Jun 3, 2008 | 03:09 PM
ufakeit's Avatar
Default 90 si rev limiter
i have a 90 si hatch and i dont know it it has a rev limiter. i have taken it into red line but never felt something hit. just curious if it had one. thanks
Old Jun 3, 2008 | 03:15 PM
sgallagher's Avatar
Default Re: 90 si rev limiter (ufakeit)
If you have a stock ecu that nobody has been into it most definatly has a rev limiter. Should be 6800rpm.
When you hit it you will know it. Sont be afraid to pull it all the way up. It likes it.
Old Jun 3, 2008 | 03:32 PM
IndySporty's Avatar
Default Re: 90 si rev limiter (sgallagher)
Yeah it should pop by 7,000 RPM if it revs over 7 then your ECU has been changed or modified. It won't hurt it to take it up to redline though it does like it
Old Jun 3, 2008 | 03:41 PM
nitewolf's Avatar
Default Re: 90 si rev limiter (IndySporty)
PM6 7,500
EFstyle's Avatar
mine, when warm hits at 7200... when not within operation temp, it should hit at 6800
Modified by EFstyle at 4:52 PM 6/3/2008
Old Jun 3, 2008 | 03:45 PM
nitewolf's Avatar
Default Re: 90 si rev limiter (EFstyle)
p28 7,500
Old Jun 3, 2008 | 03:53 PM
EFstyle's Avatar
Default Re: 90 si rev limiter (nitewolf)
my bad...red line is 7200...
Old Jun 3, 2008 | 04:06 PM
ef-hatchcrap's Avatar
The pm6 actaully has 3 rev limits. When the car is completey cold or out of time a little bit it will hit 6800.
Semi warm it will hit 7200 and when the motor is fully warn you will have a rev limit 7500
Old Jun 4, 2008 | 02:54 PM
ufakeit's Avatar
Default Re: 90 si rev limiter (ef-hatchcrap)
thanks for all the help
cwbu94
Nov 30, 2017 04:10 PM
severaltony
Mar 15, 2012 11:23 PM
specialized108
Dec 31, 2008 10:44 AM
slow91crx
14
Jan 22, 2005 06:18 PM
johnzm
Nov 3, 2002 04:35 PM
