Problem With New Cobalt GTS Pad Install?
Old Jun 3, 2008 | 01:46 PM
richardb53's Avatar
Default Problem With New Cobalt GTS Pad Install?
Well prepping for EXPO8, I installed new Coblt GTS pads on my 01 ITR abourt 150 miles ago and they don't seem to be seated properly. It looks like only about 50% of the pad is contacting the rotor. I bedded the pads close to what they recommend. They also squeek like hell after the pedal release for 50 to 100 feet. The rotors are new as well. Rotors seem to be fine as there is no wobble or indication of warpage. Take a look at the pics below and tell me what you think. Thanks.
Left side:
Right side:
Old Jun 3, 2008 | 01:50 PM
RTW DC2R's Avatar
hows the bite? they look like they are hardly touching? any wheel bearing "play"? my GT Sports used to make a ton of noise under normal driving off the brakes. I had a bad wheel bearing with a lot of play and the pads were just riding the rotor. replaced the bearing and most of the noise is gone. those look to me like they need to be bedded some more. 70mph-0 HARD on the brakes.
Old Jun 3, 2008 | 01:57 PM
jgirard's Avatar
Default Re: (RTW DC2R)
what are the proper bedding techniques, I will be replacing my front and back with these tonight
Old Jun 3, 2008 | 01:59 PM
walker111's Avatar
I think there was just a bad batch of pads made by Cobalt.....Mine did the samething, finally after 2000 road miles and 150 hard track miles, they are finally using all of the rotor. Granted I was only having the problem on one side, looked the exact same.
Old Jun 3, 2008 | 02:01 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (walker111)
a couple good really hard stops will get those pads fully seated.....if not, it may take a a hundred miles or so...and they will eventually wear unevenly- will still perform good though
Old Jun 3, 2008 | 02:05 PM
Dave_B's Avatar
I agree... Bed them harder/more.
you should get good contact after some hard bedding.
Old Jun 3, 2008 | 02:06 PM
richardb53's Avatar
Default Re: (jgirard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jgirard &raquo;</TD></TR><TR><TD CLASS="quote">what are the proper bedding techniques, I will be replacing my front and back with these tonight</TD></TR></TABLE>
Go here.
http://www.hawkperformance.com...s.php
Old Jun 3, 2008 | 02:07 PM
jgirard's Avatar
Default Re: (richardb53)
Thanks Richard
Old Jun 3, 2008 | 02:09 PM
richardb53's Avatar
They bite great now, wonder how good they will be with full contact!
Old Jun 3, 2008 | 02:20 PM
ithrowpoop's Avatar
mine did the same thing front and rear. after about 100 miles and 2 auto x's they got better. they still squeal worse than a stuck pig.
Old Jun 3, 2008 | 02:40 PM
get RIGHT's Avatar
Default Re: (ithrowpoop)
After going thru 3 sets of GTS's. You REALLY have to bed these hard. Don't be shy about it.
Old Jun 3, 2008 | 02:48 PM
97 TYPE-R 312's Avatar
Default Re: (get RIGHT)
This was the problem some of us were going through last at AT Expo.
https://honda-tech.com/zerothread?id=2082004
Just to see if this comes up again...
-Victor
Old Jun 3, 2008 | 03:54 PM
white rocket's Avatar
Default Re: (97 TYPE-R 312)
I would get up to about 60-70mph and hit the brakes HARD until I get down to 5mph. Then do it all over again. Took about 5 to 6 go's to get them in there. The squeaking should go away after the pads are worn down a bit.
Old Jun 3, 2008 | 04:06 PM
itralex's Avatar
Default Re: (white rocket)
you need to bed these pads really HARD
I bedded mine at night and saw sparks fly past my window
Old Jun 4, 2008 | 03:50 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by white rocket &raquo;</TD></TR><TR><TD CLASS="quote">I would get up to about 60-70mph and hit the brakes HARD until I get down to 5mph. Then do it all over again. Took about 5 to 6 go's to get them in there. The squeaking should go away after the pads are worn down a bit.</TD></TR></TABLE>
Haha, after being frustrated with this after a couple of weeks, I did a 120mph to 5mph with smoke pouring from both wheels.... Still didnt work til after/during the we-todd event.
Old Jun 4, 2008 | 03:57 AM
RTW DC2R's Avatar
i didnt know about that tab issue, so Im gonna have a look
Old Jun 4, 2008 | 04:23 AM
Jon D's Avatar
&lt;---still supporting our EXPO Sponsor!
Everyone experiences growing pains, er'ya know?
Old Jun 4, 2008 | 04:25 AM
jgirard's Avatar
Default Re: (Jon D)
Got my GTS's on last night, they do squeal like a pig but man do they bite, need to hit 'em harder though I believe
Old Jun 4, 2008 | 05:32 AM
citrus3000psi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">
Haha, after being frustrated with this after a couple of weeks, I did a 120mph to 5mph with smoke pouring from both wheels.... Still didnt work til after/during the we-todd event.</TD></TR></TABLE>
Are you locking the tires up? Because this will not bed in brakes.
Old Jun 4, 2008 | 05:59 AM
R.Kelley's Avatar
Default Re: (citrus3000psi)
i had the tab problem at last expo. love these pads
Old Jun 4, 2008 | 07:07 AM
walker111's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrus3000psi &raquo;</TD></TR><TR><TD CLASS="quote">
Are you locking the tires up? Because this will not bed in brakes. </TD></TR></TABLE>
lol, of course not.
Old Jun 4, 2008 | 07:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by walker111 &raquo;</TD></TR><TR><TD CLASS="quote">Haha, after being frustrated with this after a couple of weeks, I did a 120mph to 5mph with smoke pouring from both wheels.... Still didnt work til after/during the we-todd event.</TD></TR></TABLE>
Yeah, my first track event this year really helped out with the squealing. They sounded like a dump truck braking before. I had some smoke screen ish going on too
Old Jun 4, 2008 | 08:13 AM
lol, of course not. </TD></TR></TABLE>
Then explain the smoke pouring out. I'm curious to know how/why they are doing this.
Old Jun 4, 2008 | 08:24 AM
RTW DC2R's Avatar
Then explain the smoke pouring out. I'm curious to know how/why they are doing this.</TD></TR></TABLE>
probably meant brake dust or smoke from the pads getting hot? i have seen sparks before at night too. it was pretty cool
Old Jun 4, 2008 | 08:53 AM
walker111's Avatar
Just from the pads getting hot...
