VTEC BOGS DOWN WHEN KICKS IN
Old Jun 3, 2008 | 11:52 AM
MIGPA26's Avatar
Default VTEC BOGS DOWN WHEN KICKS IN
I have a 91 civic hatchback si w/b16 swap.
Im not throwing any codes
My vtec bogs down when kicks in, loss of power. Doesnt kick me back with power boost. Also when I start it it idles at around 300rpm, then wants to die, but when its warm it idles fine at 750rpm..
Will probably change out fuel filter. Check timing, I already checked fuel injectors & fuel injector filters which where all clean.
I just put on a new cat converter..
Any help would be greatly appriciated..
Old Jun 6, 2008 | 10:46 AM
DTA-Zombie's Avatar
okay so my first post failed for some reason. What is ur vtec engagement point at currently? Sounds like it is too low - chipped ecu? running obd0 or obd1? jumper or full conversion if obd1 - idle could be a number of things.
Old Jun 6, 2008 | 11:16 AM
MIGPA26's Avatar
Default Re: (DTA-Zombie)
I fixed the idle problem.
Its a obdo engine and ecu. The vtec kicks in at 5200 rpm. How can I lower that, get a vtec controller.
I was looking at the map sensor, it had a tee on it and was sucking in air, I fixed that, vtec is a little more smooth still bogs a little, doesnt kick me back with power!! Car warms up fine with no problems.
Also I have non-vtec spark plug wires on the car, can that be it. I didnt put them on they where on it already on car. From a 93 acura integra ls non-vtec. Im going to put on magnecor comps. dohc vtec spark plug wires on it..
DarikDisease
Aug 26, 2008 01:29 PM
cpgottabuh
Jul 23, 2008 12:11 PM
ken2830
Dec 25, 2006 11:08 AM
89 z6 civc
14
Nov 3, 2005 07:11 PM
allmotor94hatch
Aug 30, 2005 06:34 AM
