HELP: CAR WONT EVEN TURN OVER JUST THIS RELAY CLICKS TIRED ANOTHER AND SAME THING JUST CLICKS
Old Jun 3, 2008 | 10:35 AM
2001B18C1GS-R's Avatar
Default HELP: CAR WONT EVEN TURN OVER JUST THIS RELAY CLICKS TIRED ANOTHER AND SAME THING JUST CLICKS
ok heres what going on i drove the car yesterday all day to and from work and drove fine turn it off and today car doesnt wanna start just goes click click...
its click for a power relay its stating its under the dash i check with honda its is a power relay seen here http://www.hondapartscheap.com...ity=0
# 25
RELAY ASSY., POWER (4P) (056700-85700) (DENSO) No Color
car doesnt turn off at all
fuel pump i can hear turn on
i tired changing main relay nothing
tired changing for another power relay nothing
check all fuses,alt,starter and tired jump starting it nothing
PLEASE ANY IDEAS ANYTHING THANKS
ORDER NEW POWER RELAY FORM HONDA 50 BUCKS
Old Jun 3, 2008 | 11:18 AM
Former User's Avatar
Default Re: HELP: CAR WONT EVEN TURN OVER JUST THIS RELAY CLICKS TIRED ANOTHER AND SAME THING JUST CLICKS (2
If the engine isn't cranking when you turn the ignition key, then try cleaning the battery terminals and connectors and making sure the ground wire from the battery is firmly attached and making good contact (no corrosion) with the chassis. Also try charging the battery or replacing it. Finally, check the starter switch above the clutch pedal and the starter cut relay.
Old Jun 3, 2008 | 12:52 PM
CivicPride97's Avatar
I had the same problem except mine wasnt a simple fix such as switching out the relay.......my timing belt came loose and f"ed up my pistons and valves so i had to get my engine replaced. i say check your belt to see if its not loose just to be sure....by the way i was going up a hill when my car suddenly just shut down and i had my timing belt replaced a month prior to the incident.....
Old Jun 3, 2008 | 12:54 PM
well i have this relay that is click the same one i just tired another one from one oh my friend cars and nothing just clicks clicks every time i turn the key that relay click and if i grab it it vibrates just tired another p75 ecu
also the car is a 95 civic hatch cx with a 95 ls ran good for about 4 months
i dont know what else to do were the starter relay and the starter switch is that lil needle like or lil black plastic piece that when the clutch is up its in and when the clutch is down its out
any other ideas let em know thanks
Old Jun 3, 2008 | 12:57 PM
gizzerhatch's Avatar
same exact thing happened to my buddy and he just took off the starter and put it back on. and it was like nothing happened. it was really strange.
Old Jun 3, 2008 | 01:14 PM
changed everything thats circle at least once
Old Jun 3, 2008 | 02:02 PM
Default Re: (2001B18C1GS-R)
Your pictures are out of focus.
Test the starter cut relay and the clutch interlock switch. These diagrams may help:
Old Jun 3, 2008 | 03:39 PM
thanks i found out it was my starter the wire was corride really bad and broke off but i had to rewire it all thanks for the help guys i owe you one thanks soo mcuh man i love honda-tech
if you guys were closer i would buy the 30 pack lol....
Brand
21
Sep 8, 2022 09:39 AM
perpetualburn
Oct 3, 2020 06:08 AM
samx227
May 17, 2014 06:14 PM
confucioussae
Sep 19, 2006 08:05 PM
DIY_Racing
Feb 23, 2003 10:48 PM
