what the heck is going on with my car??? can someone helop me now?
okay so when i was driving today i shifted into 3rd well outta no where it just seemed like i was over reving the engine so i put it into 4th....well when i did that it seemed like it had no power then i could hear my intake being louder then normal.....
its throwing out code 16 and 1 from the ECU
heres a link to the video i made
http://myspacetv.com/index.cfm...66318
also i did shift into 1st and 2nd and then so forth....
i own a 1990 honda civic 1500DX
also i took off the air intake stuff and was looking to see if it was the fuel injector well at least the top one was working but i have no clue if the bottom one is....while i was stepping on the gas and had the intake stuff off it started to smoke up a little bit....hopefully this can help out too?
Modified by hassan21 at 3:27 PM 6/3/2008
Modified by hassan21 at 3:31 PM 6/3/2008
https://honda-tech.com/zerothread/1901557
1 and 16 is o2 and injector
how long were you in first for?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hassan21 »</TD></TR><TR><TD CLASS="quote">one more thing gas is shooting out of the throtle body when i have the intake off</TD></TR></TABLE>
That doesnt sound toooo safe, but if you say fuel is coming out from somewhere on the manifold then most likely from what Hanmin said it can be a fuel injector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hanmin »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread/1901557
how long were you in first for?</TD></TR></TABLE>
code 16 is a fuel injector like the other guy said ,what could be happening s you have an injector stuck open ,which would throw a code 16 ,then the unburned fuel is messing with the o2 which is probly where your code 1 (o2 sensor) is comeing from
so i replaced the top one the brown one on my car just not the green one.....i dont know which one does what
the brown is on top
and
the green is on the bottom
on the throtle body
the brown is on top
and
on the throtle body
Fix the codes first, also unplug battery for 5 mins to reset ecu to clear the code or CEL./
Also brown injector on top green on bottom.
Modified by traxxasx at 1:40 AM 6/4/2008
ok well today i worked on the wiring and cleared the codes and Code 16 was the one causing my car to smoke big time. now the car dont smoke as when i started to drive. hope it stays this way.....
hondakid09
Jan 10, 2010 04:54 PM
iampeetor
Jul 3, 2004 07:37 AM
