overheating
Old Jun 3, 2008 | 09:01 AM
corince06's Avatar
Default overheating
i have a 92 si with a 95 gsr swap...my coolant temp gauge says im running at 210 to 250...i have an aftermarket radiator and it is full...i was wondering if anyone could help me figure out why its overheating??
Old Jun 3, 2008 | 09:07 AM
smonblt's Avatar
Default Re: overheating (corince06)
Did you bleed the system after you did the radiator swap?
Old Jun 3, 2008 | 09:13 AM
gibsanez's Avatar
Is your coolant bled? Does your fan come on? How old is the T-stat?
Old Jun 4, 2008 | 08:59 AM
corince06's Avatar
Default Re: overheating (gibsanez)
im not sure if the radiator has been bled it came with the engine swap...my fan does come on...and im not sure how old the t-stat is...is there any way besides using a temp gun to see if my temp gauge is working or not?...cause i dont think its right
Old Jun 4, 2008 | 09:20 AM
gibsanez's Avatar
replace the thermostat and then bleed the coolant.
Old Jun 4, 2008 | 09:58 AM
k20superchargedtuboitbs's Avatar
could be a water pump
Old Jun 5, 2008 | 04:52 AM
corince06's Avatar
Default Re: (k20superchargedtuboitbs)
ok ill try replacing the tstat...but how do you bleed the coolant?
TooFastVTEC
11
Jul 20, 2012 11:53 AM
dirty5outhazn
Mar 20, 2012 04:07 PM
EB90RS
Feb 12, 2008 08:21 PM
mrx
Jul 4, 2006 07:44 AM
Albino Dragon
Apr 18, 2002 10:15 PM
