H23 block + Type S pistons
Old Jun 2, 2008 | 10:17 PM
support1's Avatar
Default H23 block + Type S pistons
I'm building my engine and i want install in H23 block with H23 crank Type S pistons and rods. I used search and saw FAQ, but i don't find results.
Anybody has finished this setup ? What CR i have, if i install H22 rods???
Old Jun 3, 2008 | 02:24 AM
98vtec's Avatar
moderator emeritus
Default Re: H23 block + Type S pistons (support1)
it would be too high compression for a street motor, in my opinion. thats in the area of 13:1 compression.
Old Jun 3, 2008 | 03:39 AM
HondaKyle's Avatar
Default FV-QR
If youre gonna build a motor why put OEM parts in? just spend a little extra money youll be better off in the long run
Old Jun 3, 2008 | 05:41 AM
vlang29's Avatar
Default Re: FV-QR (HondaKyle)
stock h22 rods on 95mm stroke with the type s will put your pistons ~.080" out of the hole. according to the compression calculator, with that combo, you will be at 15.82:1 comp. Good luck use the h23 rods. Even with those, and a stock thickness headgasket, your cr is about 13:1.
with the extra stroke of the h23, them type s pistons just make crazy compression unless you get a thicker headgasket. in which case you could just as well use base h22 pistons and a stock headgasket.
also i forgot to ask which head you are using.. I'm assuming the h22, but the smaller combustion chamber on the H23 head will put all of these values almost a full number higher
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaKyle &raquo;</TD></TR><TR><TD CLASS="quote">If youre gonna build a motor why put OEM parts in? just spend a little extra money youll be better off in the long run</TD></TR></TABLE>
better parts aren't a little exra, they're a lot.. especially if you go forged. With an h23 stroke you can bust out some serious compression with stock FRM compatible h22 pistons.
Old Jun 3, 2008 | 07:16 AM
paniaguae640's Avatar
aries forged pistons
Old Jun 3, 2008 | 07:56 AM
vlang29's Avatar
Default Re: (paniaguae640)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paniaguae640 &raquo;</TD></TR><TR><TD CLASS="quote">aries forged pistons </TD></TR></TABLE>
which requires sleeving, which he isn't doing
Old Jun 3, 2008 | 09:46 AM
8_6 luder's Avatar
Default Re: (vlang29)
Its a funny concept , the more you spend the more you have to spend .
Old Jun 3, 2008 | 09:06 PM
victorSCP's Avatar
Default Re: (8_6 luder)
also remember that type s pistons have floating wrist pins so that would need to be modded
REDLUDE4WS
Oct 29, 2012 04:44 PM
h22_SOL
Apr 25, 2008 03:20 PM
jdm knight
Feb 22, 2006 01:00 PM
Sam1am26
Mar 7, 2004 02:14 PM
AndyD
Nov 30, 2002 05:52 AM
