My EJ8 shaved, tucked, and repainted Blaze red crystal
SOLD
http://cgi.ebay.com/ebaymotors/ws/eB...%3AMESELX%3AIT
http://www.autotrader.com/fyc/vdp.jsp?car_id=260173329
All questions and comments welcome. Most of the work I did myself and it was my first time at it, so let me know what you think.
Before:
Here's the rundown. After Nopi, I decided to shave my bay and do better wire tuck. Being an amateur welder and having access to just a stick welder, it took me just under a month to weld, grind, and have the bay ready for filler. I worked after hours and on the weekend at work. I had help here and there on the difficult parts. It was then taken to the body shop. There I filled and sanded the bay. Most of the bay had to be hand sanded. I came back and did the same thing after primer. This is where I left off. The rest of the exterior and paint was professionally handled. In the meantime, I finished my harness. Reassembly didn't take long. I had the engine running the day after I got the car back from paint.
After:
I welded in some plates to cover the two holes behind each headlight. The driver's side was for the a/c and washer reservoir. The passenger side hole was for the oem air box assembly.
Here is a shot of the seam sealer. I just sanded down the factory sealer to make it look smoother and less noticeable.
The support here alone had 25 holes to weld up. This is counting from fender to fender.
Harness and inverted injectors
Tacky or tasteful. I love this beer.
Interior
Show pic
Special thanks to:
-Justin-, Brewer, and Chris miller for the pics
Tracy (speeddreamz.com) for allowing me to use the shop (Mobile Electronics and Performance in Tuscaloosa, AL) after work hours
Tracy and Yosuke for helping on the hard welds
Ryan Clough at Automations in Bessemer, AL for the body and paint
Chase with the wire tuck tips
Before:
After:
Interior
Show pic
Special thanks to:
Thanks guys! I was leaning towards the Chevrolet red, at first, that looks similar to this color. Ryan noticed it had a good bit of purple in it. You've probably seen the color on the new Tahoe. Anyways, Ryan pointed me towards this color. This color is on Chargers, Ram p/u, crossfire, as well as other chrysler vehicles.
Most people would think it was out of a ppg catalog. Did you?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware »</TD></TR><TR><TD CLASS="quote">color is amazing. Side shots ASAP!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedaddict »</TD></TR><TR><TD CLASS="quote">love the engine bay...the shaving and sanding of the seam sealer looks killer
I wasn't comfortable messing with it and the brake lines like some people do with their tucks. Sanding the factory seam sealer was an afterthought once I got started on the bay at Automations. I wasn't really sure how it would turn out. Thanks for the comments.
</TD></TR></TABLE>I wasn't comfortable messing with it and the brake lines like some people do with their tucks. Sanding the factory seam sealer was an afterthought once I got started on the bay at Automations. I wasn't really sure how it would turn out. Thanks for the comments.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.OB*GYN_Rhett »</TD></TR><TR><TD CLASS="quote">Personally, would have kept it white, but your work is very good
That was the original plan and without a shaved bay. But, I told myself if I was to spend the money, the paint better stand out. And, if I was paint it, I might was well shave the bay. It was a pretty enormous task for someone whose never welded or had to do body work.
</TD></TR></TABLE>That was the original plan and without a shaved bay. But, I told myself if I was to spend the money, the paint better stand out. And, if I was paint it, I might was well shave the bay. It was a pretty enormous task for someone whose never welded or had to do body work.
