9s cars how much boost to launch?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremvw »</TD></TR><TR><TD CLASS="quote">just wondering all you fast cas, how much boost are you launching with and do you ramp it up afterwards
thanks</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1junkycivic »</TD></TR><TR><TD CLASS="quote">good luck on that.</TD></TR></TABLE>
The answer's are, just enough & yes.
Every car is different. There are so many variables it's hard to say they all use the same psi.
Think about what needs to happen when you launch the car. Then work out in your mind what you think would work and start there...it's all a learning process we all have to go through.
Keep records so you have some knowledge of what worked and what did not work so you don't repeat the same mistakes.
We only launch at 7-8 PSI but....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1992Si »</TD></TR><TR><TD CLASS="quote">
....he ^^^^^^^ is right. Every set up is different. Check your logs and see were you need to pull or add some power. What works for me, might not work for you.
Most informative post you have ever made on this forum
still working bugs out.
