Piston To Valve Clearance/Headgasket/Compression ITR HELP!
Old Jun 2, 2008 | 05:56 PM
WheaMyRyceGo's Avatar
Default Piston To Valve Clearance/Headgasket/Compression ITR HELP!
I've searched around but still couldn't get an exact answer. I wanted to know if I should be fine.
I have a 2000 ITR. Im about to put in the supertech valvetrain. dual springs/flat faced valves/titanium retainers/bronze guides. I was also thinking about throwing in a two-layer headgasket.
My question is should I be worried about Piston To Valve clearance?
What is my compression going to be?
The local shop said it'll sit right at 11.5:1 and that I'd need to use race gas.
Also, I just found out that my pistons might have been changed to Factory Overbore, Will this change anything?
Your help is greatly appreciated and thank you.
Old Jun 2, 2008 | 07:45 PM
IntegraType-R's Avatar
Default Re: Piston To Valve Clearance/Headgasket/Compression ITR HELP! (WheaMyRyceGo)
No you'lll be fine.
Old Jun 2, 2008 | 10:47 PM
honda_ef9's Avatar
having to use race gas on 11.5-1, . Let me guess chonge told you this ? you will be fine with 91. What cams ? also be sure to get tuned......by someone other then revline caugh caugh modified by kc ......btw your compession will be at 11-1 with a 2 layer
Old Jun 2, 2008 | 11:37 PM
Default Re: (honda_ef9)
hahaha, so how did u figure i was from around that area? actually it was scott who told me that and i wouldnt give my business to revline anyway chuong tried to f my brother over and ive known his whole family for about 10 years now
Old Jun 17, 2008 | 06:15 PM
bigkvn77's Avatar
Default Re: (WheaMyRyceGo)
With a good tuner you can easily run your compression as high as 12 to 12.5-1 on pump. Why raise the compression just to lower it with a dual layer headgasket. Run a stock headgasket and get a good tune. The key will be in the tune.
Old Jun 18, 2008 | 08:32 AM
broke91hatch's Avatar
I like the location WheaMyRyceGo, but I know where you are located.
Old Jun 18, 2008 | 08:43 AM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
Default Re: Piston To Valve Clearance/Headgasket/Compression ITR HELP! (IntegraType-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">No you'lll be fine.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigkvn77 &raquo;</TD></TR><TR><TD CLASS="quote">With a good tuner you can easily run your compression as high as 12 to 12.5-1 on pump. Why raise the compression just to lower it with a dual layer headgasket. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ef9 &raquo;</TD></TR><TR><TD CLASS="quote">.btw your compession will be at 11-1 with a 2 layer </TD></TR></TABLE>
/cry
2 layer HG = RAISES compression. Stock is 3 layer.
No [freak]ing way is anyone running 12.5:1 on 91 safely. And even if you could... why? You would make more power at 11:1 advancing your timing.
Why tell someone with oversized valves, 2 layer hg, mystery cams and who knows what pistons that he will be fine with p2v contact? You have no idea, he needs to ask his engine builder.
RHDintegXsi
Jun 17, 2005 01:25 PM
bboyoxygen
Oct 31, 2004 04:06 PM
done
Sep 7, 2004 09:57 AM
IMPATIENT
Jan 31, 2004 01:01 PM
EleanoR
Mar 24, 2002 06:51 AM
