gsr cluster in crx fuel gauge dont work
Old Jun 2, 2008 | 05:46 PM
anotherstar_noz's Avatar
Default gsr cluster in crx fuel gauge dont work
i just insatlled a 97 gsr cluster in my 91 crx and everything works except the fuel gauge...i ckecked the wiring three times and its correct . it just sits on empty help will be greatly appreciated
Old Jun 2, 2008 | 07:29 PM
Aesthetic Gains's Avatar
Dos Pupusas
Default Re: gsr cluster in crx fuel gauge dont work (anotherstar_noz)
I just got done installing a 2001 ITR cluster in my 90 CRX. At first I had that problem, than i checked the grounds and one of them was a bit loose in the connector. It could also be that you might be low on fuel. What I also noticed is that the write ups might not be correct for all clusters and models. What I would also suggest is looking at the back of the cluster and follow the fuel gauge circuit on both clusters. Put the wire from the EF cluster that was in the fuel gauge spot and install that on your DC plug matching the fuel gauge circuit on the DC cluster. If I remember correctly there was a T on the left side for Temperature and F on the right for Fuel... Hope this helps...
Old Jun 3, 2008 | 04:11 PM
nitewolf's Avatar
Default Re: gsr cluster in crx fuel gauge dont work (Tonio)
can you tell me how you wired the vss up?
Old Jun 3, 2008 | 04:21 PM
Turbo Dan's Avatar
Default Re: gsr cluster in crx fuel gauge dont work (nitewolf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">can you tell me how you wired the vss up? </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=2286646
Old Jun 3, 2008 | 04:52 PM
nitewolf's Avatar
Default Re: gsr cluster in crx fuel gauge dont work (Turbo Dan)
good looken turbo dan
Old Jun 3, 2008 | 04:58 PM
nitewolf's Avatar
00y8 vss/95si plug...same power ground signal?
Old Jun 3, 2008 | 05:40 PM
zccr-xsi's Avatar
[QUOTE=nitewolf]00y8 vss/95si plug...same power ground signal?[/QUOTE
YUP!
IM USEING A 95 VSS PLUG for my ls cluster.i had same prob. with my gsr cluster and my speedo guage didnt work in the gsr cluster so i swtiched to an ls one.and yes the dash wiring is the same for gsr and ls
and any ideals on how u guys mounted the cluster and how many gaps did u guys get rid of?heres how my turned out.
Modified by zccr-xsi at 9:46 PM 6/3/2008
Old Jun 9, 2008 | 06:26 PM
Matthew.Mandley's Avatar
Hey Man I am haveing the same problem in my 91 crx si the fuel gauge will go to empty and wont come up did you fix you problem and if so can you help me
Old Jun 10, 2008 | 01:24 PM
zccr-xsi's Avatar
have u guys even tested or replced the fuel sending unit in the tank?thats a good start.
Old Jun 10, 2008 | 05:15 PM
DARKB20's Avatar
Default Re: (zccr-xsi)
nice
Old Jun 10, 2008 | 05:29 PM
my fuel gauge was working before the gauge swap ...so the fuel sender worked....how can i check if it works...?
Old Jun 11, 2008 | 06:36 AM
K2e2vin's Avatar
It could be wired wrong. I had that problem; I was using the wrong year(I think) gauge cluster plugs so it had the fuel level wire in a different spot. I ended up just following the traces on the circuit to figure it out. Works fine now.
Old Jun 11, 2008 | 09:07 PM
Default Re: (K2e2vin)
that was it thanks k2e2vin checking the circuit fixed the problem .
the pinout i got was wrong it said a3 ws the fuel gauge wire but it wasnt it was a1
now just to get the speedo going........
Old Jun 12, 2008 | 04:09 AM
zccr-xsi's Avatar
Default Re: (anotherstar_noz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by anotherstar_noz &raquo;</TD></TR><TR><TD CLASS="quote">that was it thanks k2e2vin checking the circuit fixed the problem .
now just to get the speedo going........ </TD></TR></TABLE>
i got a eg vss for sale for u want it.
Old Jun 13, 2008 | 04:03 PM
thefiztec
Aug 7, 2013 04:29 PM
PrettyMicky951
May 13, 2009 09:46 PM
anotherstar_noz
Jun 9, 2008 12:07 PM
fubulous
Apr 22, 2004 05:56 AM
CWBETB
May 28, 2002 07:40 AM
