Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
quick transmission ?
Old Jun 2, 2008 | 05:34 PM
hondachris1994's Avatar
Default quick transmission ?
how many quarts does a 2001 civic lx tranny take??
Old Jun 2, 2008 | 08:19 PM
kuNhoHan's Avatar
Default Re: (hondacivic03)
hmm iono about the last post but i believe 3 quarts is fine for the transmission ... just fill and check the dipstick
Old Jun 2, 2008 | 08:29 PM
anyonr have a link so i know 4 sure? I cant start the car till tommorow cause I lost the key, so I have to get another key tommorow. I put 4 quarts in so I need to know if I have to take any fluid out
Modified by hondachris1994 at 12:35 AM 6/3/2008
Old Jun 2, 2008 | 09:16 PM
toyomatt84's Avatar
Sanji
Default Re: (hondachris1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">anyonr have a link so i know 4 sure? I cant start the car till tommorow cause I lost the key, so I have to get another key tommorow. I put 4 quarts in so I need to know if I have to take any fluid out
Modified by hondachris1994 at 12:35 AM 6/3/2008</TD></TR></TABLE>
Where are you filling the transmission at, and is your car level? Because you should be filling the transmission up to the point that which excess fluid should be coming out of the fill port.
Old Jun 2, 2008 | 10:37 PM
vroomboom's Avatar
* B A N N E D *
noob question... mine is a manual, what fluids do I have to top off? Just the clutch and brake fluid?
Old Jun 2, 2008 | 10:49 PM
toyomatt84's Avatar
Sanji
Default Re: (vroomboom)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vroomboom &raquo;</TD></TR><TR><TD CLASS="quote">noob question... mine is a manual, what fluids do I have to top off? Just the clutch and brake fluid?</TD></TR></TABLE>
What are you talking about? Why would you be needing to "top off fluids"?
Old Jun 3, 2008 | 12:25 PM
vroomboom's Avatar
* B A N N E D *
alright question came off wrong, what fluids should I fill since I have a manual?
*first manual car
Old Jun 3, 2008 | 01:40 PM
toyomatt84's Avatar
Sanji
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vroomboom &raquo;</TD></TR><TR><TD CLASS="quote">alright question came off wrong, what fluids should I fill since I have a manual?
*first manual car</TD></TR></TABLE>
Again, what are you trying to do with it? Meaning, why do you want to change fluids? What are you trying to achieve?
Old Jun 3, 2008 | 03:28 PM
whitexpinoy's Avatar
Default Re: (toyomatt84)
QUESTION i got a manual swap. i kno that theres auto trans fluid and manual trans fluid but i havent switched it.... should i switch the auto trans fluid to manual since i did a manual swap?
Old Jun 3, 2008 | 07:17 PM
toyomatt84's Avatar
Sanji
Default Re: (whitexpinoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whitexpinoy &raquo;</TD></TR><TR><TD CLASS="quote">QUESTION i got a manual swap. i kno that theres auto trans fluid and manual trans fluid but i havent switched it.... should i switch the auto trans fluid to manual since i did a manual swap?</TD></TR></TABLE>
You should always run the type of transmission fluid, as your car has. Meaning, if you have a manual transmission, run manual transmission fluid. You can cause damage running the wrong fluid.
uneek4dr
Oct 11, 2006 08:08 PM
usdm97DC4
Oct 6, 2005 09:37 PM
ctownintegra
Jun 12, 2005 09:12 PM
imadigitalgod
Oct 22, 2004 03:21 PM
DeDonDeRosa
Jun 9, 2003 11:58 AM
