Frustrating Misfire
well i just had my engine rebuilt , and towards the end of the break in period (500 miles ) i got a CEL , went to Autozone and it was a random misfire on all 4 cylinders...
well my alternator died a couple days later , so while i sourced an alternator i replaced the cap , rotor , spark plugs , and the wires...
put another alternator in today , went for a drive...all was good and 30 min later...CEL blinking again...
i thought i surely solved the problem , even after finding my rotor screw chilling at the top of my distributor...what can be done??
are your valves adjusted properly? Have you checked the timing?
I had a similar problem with mine, I had messed up the adjustment, but re-did it and it ran great afterward.
also, what do you mean by rebuilt? stock components etc?
yea , new crank, rods , bearings , rings , headgasket , oil pump , water pump , timing belt and gaskets/seals...i do need to adjust my valves...
my o2 sensor is unplugged also...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benefitx »</TD></TR><TR><TD CLASS="quote">yea , new crank, rods , bearings , rings , headgasket , oil pump , water pump , timing belt and gaskets/seals...i do need to adjust my valves...
my o2 sensor is unplugged also...</TD></TR></TABLE>
May i ask why you replaced all those parts?
Was there a problem with the motor ?
I ask because it seems like alot of money to put into OEM parts , ya know ?
motor was knocking from being run low on oil due to bad rings...
dont remember the exact code , but its a random misfire on all 4 cylinders
yea ive replaced alot of parts, i dont know why it is still misfiring , the only other thing that might be causing it is the o2 sensor being unplugged...might replaced the spark plugs again maybe they are fouled??
fuel pump is a walbro 255 on stock fuel rail/injectors/FPR...
i was thinking fuel also because it did not throw any codes in the break in period then i replaced everything when it did...
are there any other codes? when does the code come on? during vtec? idle? normal driving?
per Helms, possible causes:
Fuel pump insufficient fuel pressure, amount of flow
fuel line clogging, blockage, leakage
fuel filter clogging
fuel pressure regulator stuck open
distributor malfunction
ignition coil wire open/leakage
ignition control module malfunction
valves carbon deposit
compression low
IAC vavle malfunction
Fast idle thermo valve malfunction
fuel does not meet owners manual spec, lack of fuel
VTEC system malfunction
test procedures and more info on page 11-78 of the integra manual
compression low
since its all cyl, I dont think its anything plug/wire related. gotta be fuel or distro IMO.
Im also running a 255lph with stock ECU, injectors, FPR, etc in my ITR and have a misfire code on cyl 2. gonna change out the pump to stock and get another plug/wire for #2 and see what that does. already changed cap/rotor/plugs before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">since its all cyl, I dont think its anything plug/wire related. gotta be fuel or distro IMO.
Im also running a 255lph with stock ECU, injectors, FPR, etc in my ITR and have a misfire code on cyl 2. gonna change out the pump to stock and get another plug/wire for #2 and see what that does. already changed cap/rotor/plugs before. </TD></TR></TABLE>
You need the o2 sensor for part throttle operation. That would cause misfire problems in all cylinders if it's not working at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro »</TD></TR><TR><TD CLASS="quote">
You need the o2 sensor for part throttle operation. That would cause misfire problems in all cylinders if it's not working at all.</TD></TR></TABLE>
did you ninja edit that bc I dont remember seeing O2 sensor in there lol
but yes plug in that O2 unless you are running some kind of EMS that does not require it that that wouldnt be the case. i assume we are talking about a stock ECU here?
thank you everyone for chiming in...
yea the o2 sensor is brand new bosch, paid 200$ for it...but when i was taking the motor out it was unplugged from the harness and the o2 sensor...and i have no idea where the wires go...
i am going to ttry seafoaming it today and if anyone can help my o2 sensor problem..
why do u need to seafoam it??
is it a wideband sensor or a replacement narrowband? sensor shouldnt be difficult to wire in assuming your ECU and harness and sensor are 4 wire...
this seems to have sorta turned into a can of worms
yea it doesnt make any sounds...
update-- i just put in a bottle of STP octane booster , and filled up...drove it and the light is not blinking (for now , i hope that did it..)
about to seafoam in a little bit...
