First ever motor build(LS/V pr3s)
Old Jun 2, 2008 | 05:20 PM
spoonef's Avatar
Default First ever motor build(LS/V pr3s)
Hey guys im building my first motor ever with my mechanic.So far the bottom end is sporting brand new pr3 pistons and arp rod bolts.Im a bit undecided on the head but leaning towards gsr for the small bump in compression.Im trying to achieve 200hp and im a bit lost on how to get there.Im going to continue searching and looking at other setups similar to mine but if anyone has any suggestions id appreciate it
Old Jun 3, 2008 | 10:22 AM
spoonef's Avatar
Default Re: First ever motor build(LS/V pr3s) (spoonef)
Got some good input from Clean Rice
Old Jun 3, 2008 | 02:37 PM
jmpgraphy's Avatar
Im running similar set up in my hatch. Very reliable. Daily drove it for 2 years with GSR cams in a b16 head. Then finally put valvetrain and cams in. I think with a good heardwork wit that block you can achieve 200+. I made 197 Unported b16 head with hsl cams on same block.
gl to you.
Old Jun 3, 2008 | 06:07 PM
spoonef's Avatar
Default Re: First ever motor build(LS/V pr3s) (jmpgraphy)
Anyone else with input?
Old Jun 3, 2008 | 06:14 PM
bmwpride's Avatar
put in a b16 head and then some type r vavletrain and cams ... And you should be good
Old Jun 3, 2008 | 06:37 PM
UncleD's Avatar
Default Re: (bmwpride)
For 200whp??^^
Old Jun 3, 2008 | 08:21 PM
spoonef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bmwpride &raquo;</TD></TR><TR><TD CLASS="quote">put in a b16 head and then some type r vavletrain and cams ... And you should be good </TD></TR></TABLE>
I doubt i can make 200 with R valvetrain and cams
Old Jun 4, 2008 | 05:48 AM
projectcivicjp's Avatar
Default Re: (spoonef)
i doubt that as well. GSR head good P&P with supertech valvetrain and flat face valves should put you there for sure
Old Jun 9, 2008 | 01:14 AM
spoonef's Avatar
Default Re: (projectcivicjp)
anyone else
Old Jun 9, 2008 | 02:25 AM
Thrizzle's Avatar
* B A N N E D *
stock head w/ manifold/springs/retainers and pro1's will make 200whp w/ that bottom end.
Just make sure that you get it tuned IMMEDIATELY after the build.
Don't run on your friends chip that ran well w/ a similar setup or any basemap crap.... save up the $ before hand and get it tune right from the get go
Old Jun 11, 2008 | 05:40 PM
spoonef's Avatar
Default Re: First ever motor build(LS/V pr3s) (Thrizzle)
I did not have my motor decked and im wondering if i should?
Old Jun 12, 2008 | 12:58 AM
Thrizzle's Avatar
* B A N N E D *
check the surface w/ a straight edge, if its good then you're in the green.
Omegax10
Mar 19, 2012 10:31 PM
SR20S13
Feb 23, 2010 06:27 PM
gsr173
Mar 10, 2008 11:03 PM
SOHCZCHatch
Nov 10, 2004 05:45 PM
