Need Help on Swapping an engine
Well i use to have a 91 DA. The DA i had before had really bad front end damage. So i bought a new shell a 93 DA and began to swap the engine from the 91 to the 93. But i didnt know they were diffrent until i had started puttin in the engine. So i realize i needed new mounts, obd1 wiring, new injectors and obd1 dizzy. So far i have the obd1 wiring and the injectors. And a mechanic had gotten the mounts for me but to me it looks like they are not the right ones. So this is what i have so far done theses are pictures of the engine in the 93 shell.
And these are the mounts and how they looked
The driver side mount
Front crossmember mount
the rear mount on the tranny
and a pic of the side on the motor
The driver's side engine mount doesn't look like an original DA mount (try buying an original one). From what I know, 90-93 DA's all have the same B-series Mounts (unless they are automatic)
Oh yea, there is a difference in the mounts. You would think that it would be the same but the 90-91 mounts are different from the 92-93 mounts but the gsr mounts are similer to the 90-91 i believe. I would have to agree with getting the oem honda mounts or you could go aftermarket and get these
http://hasport.com/shop/produc...d=158
or these
http://www.innovativemounts.co...19351
or these
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rgaray »</TD></TR><TR><TD CLASS="quote">Sorry, but that looks like an OBDII motor from a 96-01 LS/RS/GS</TD></TR></TABLE>
? whats your point?
? whats your point?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsrIntegra789 »</TD></TR><TR><TD CLASS="quote">
? whats your point?</TD></TR></TABLE>
Nothing, just pointing out the obvious?[
well the engine is a b20b with an 91 ls tranny.. and it was obd0 but i just bought the obd1 wiring and will make it obd1. Well do u guys think i just need the drivers side mount ??
stackz
Aug 30, 2006 10:04 AM
