swap options? keeping tranny.
Old Jun 2, 2008 | 03:52 PM
kip0485's Avatar
Default swap options? keeping tranny.
i may end up needing to swap out my engine, and i want to up size, currently have a b18a1 block, with a gsr head, i have a 2000 civic si tranny with a 7lb aluminum flywheel, and a six puck clutch, 5th gear is touchy, i want to find a 6spd, in time, are there any out there that flywheel and clutch will work in? but right now the main issue is, keeping that in mind, what motor do u recomend?
Old Jun 2, 2008 | 05:59 PM
Agnom's Avatar
Default Re: swap options? keeping tranny. (kip0485)
Honda do not make 6 speed for B series engine, you might have to go K series swap...
Old Jun 3, 2008 | 01:29 PM
vtecb18c's Avatar
Default Re: swap options? keeping tranny. (Agnom)
do ls/v turbo and rebuild the S tranny or go jdm ys1 if you got the money
Old Jun 9, 2008 | 05:18 PM
kip0485's Avatar
Default Re: swap options? keeping tranny. (vtecb18c)
well, heres the deal, there is repairing my block, so really thats where i am at. rsx's are the k series engines correct? would a k22 or k23 (type s, yes?) fit in my car? its a 92 civic hatch. and does anyone know if the clutch is same as well?
Old Jun 9, 2008 | 05:23 PM
sorrule's Avatar
it k's will fit in your car with the correct mount kit (such as from hasport) and other components. The clutch and flywheel is different for the k and b series. Basically B series tranny will only fit on b series motors without modifications.
Old Jun 9, 2008 | 05:30 PM
kip0485's Avatar
Default Re: (sorrule)
so will my tranny from a b18 work on a b20?
Old Jun 9, 2008 | 05:59 PM
vtecb18c's Avatar
Default Re: (kip0485)
yes
Old Jun 16, 2008 | 04:14 PM
kip0485's Avatar
so the guy i bought the car from said it had type r pistons, and since i have the engine pulled apart, i figured id find out. so the question is, does ne one know the code that is stamped on a type r piston?
Old Jun 16, 2008 | 04:26 PM
lunatics209's Avatar
itr p73 if i were you i'd research the latest hype. alot of folks are running the h2b setup which you can keep your tranny. research h2b you might just want to jump the bandwagon cause i have.!
Old Jun 16, 2008 | 06:05 PM
kip0485's Avatar
Default Re: swap options? keeping tranny. (lunatics209)
what is the h2b from?
Old Jun 16, 2008 | 07:00 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kip0485 &raquo;</TD></TR><TR><TD CLASS="quote">what is the h2b from?</TD></TR></TABLE>
h2b a using an h series motor with slight mods and a custom kit to bolt a b series tranny on. drop it right into a civic/integra utilizing b series parts. just search. its really crazy with h2b now. pretty sure you'll find alot of info, dyno numbers, and track numbers about them.
Old Jun 17, 2008 | 03:08 PM
kip0485's Avatar
ok, so my pistons are not type r's, not sure which stamp it is but on the outside "pr3" is stamped, and on the inside it has stamped " 38155 tae h32" are these just stock ls pistons?
Old Jun 17, 2008 | 04:38 PM
sorrule's Avatar
US Spec B16's
Old Jun 17, 2008 | 06:17 PM
kip0485's Avatar
is the bore of a b16 and b18 the same? because my blolck is stamped b18a1
Old Jun 18, 2008 | 04:20 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kip0485 &raquo;</TD></TR><TR><TD CLASS="quote">is the bore of a b16 and b18 the same? because my blolck is stamped b18a1</TD></TR></TABLE>
B16/B17/B18A/B/C/B = 81mm bore
nostro
Mar 9, 2013 12:22 PM
dewey_civic
Aug 28, 2012 03:01 PM
crxd16
Mar 8, 2008 02:38 PM
cbmprelude
Nov 8, 2005 03:31 PM
dc5mikeydc5
Sep 11, 2005 02:09 PM
